20 Most Recent
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Questions & Answers
Screen Gone
reset your diaplsy setting s to factory defaults.
also check your power supply waltage and earthing properly working
REGZA 42HL167 Won't turn on
I found it!!
In my case, the 42HL167, the CPU pcb (most commonly referred to the SEINE PCB) is having issues booting and just isn't starting up.
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
I agree -- it seems like a design flaw. What cracks me up is that the places I called for a replacement SEINE PCB require the core (the bad PCB). Well GEE, why is that!?!? EASY FIX MAYBE?
It was. Too easy. Shamefully easy.
-Ben
Buzzing tv after power surge
Get the estimate. When your insurance company sees it, believe me, they won't buck at replacing your TV _especially since the prices of TV's have come down over the years while the quality and resolution has skyrocketed. . .
Intermittent error. Remote inactive with volume
Tries tv unplug,replug it back like about an hour later.Go into tv menu goto PICTURE go down to do resetting.To resetting the tv Tuner signal board back to factory setting,now it should be working a gain.If still have the same result.Than the manual control PCB board like power,volume - + so on.. is short and the causes.Tries wwebsites like Shopjimmy.com,Ebay.com to buy a furbish Manual control PCB bosard for the replacement.
I have a toshiba regza
The model number should be on a white sticker on the back of the TV. If you can find it, please post back and I will obtain the correct code for your Sky remote.
There are some Generic codes for Toshiba TVs which are:
0536 1536 and 1221 for Rev 8 remotes
0063 0536 and 1121 for Rev 6 remotes
0063 0121 and 0536 for Rev 4 remotes
You can find the Rev number of your Sky remote on a sticker inside the battery compartment. If it just says RC1600/00 then you have the original Sky remote, but you can still try the above codes.
If you need instructions on programming the remote, please post back with both your model number and Sky remote Rev number and I will post the codes and instructions.
Regards,
BElectric
Have a Toshiba 26A3000R TV
Sky don't list a specific code for the 26A3000R, but there are some generic codes for Toshiba TVs with a Rev 4 remote:
0536, 0581, 0063, 0473, 0530, 0746, 0121, 0742, 0173
Try each of the above codes until you find one that works the power and volume functions. If you have no success or you need code entry instructions, please post back and I will try to assist you further.
Regards,
BElectric
Color problem
32inch lcd toshiba regza the screen has a yellow tint
