Everything was working fine. disconnected cable box from tv to put on another tv. reconnected cable box to tv with surround sound now can't get sound for tuner, tv or dvd player
Check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
let me know your tv brand and I can dig deeper for the menu screen options.
Lets assume you did not change any of the hook ups from your prior setup. Get into the menu screen options of your television and find and select audio. Generally there is a selection where you can shut off the internal audio and select external source or something with similar verbiage.
did you ever get sound out??? Please let me know.
Two years after your last post....the same thing happened to my Denon AVR 687. Last night it was working fine, this morning NOTHING. It kept saying H/P only and for the life of me, I didn't know what that was. I found a headset plug and my stereo headset, plugged it in and POOF....started working fine. All is well in our house this morning. Thnaks, I'm glad I checked here.
I need more info..........tv speakers work ...........how do I check if audio is going out?
I connected the headphones as suggested and could hear the tuner/tv etc. So I unpluged the headphones and the unit clicked and the speakers began to work. I believe that the "status" that I was getting of H/P only was headphones only.
Thank you so very much for your suggestion.........the unit now works fine. Don't know how it got stuck on headphones since we never used them, but problem solved thanks to your suggestion!!!
Thanks again!
