20 Most Recent
Denon AVR-2802 Questions & Answers
Master reset
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the "a" and "b" button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the "a" and "b" button and the receiver will reset it self. The receiver's microprocessor has now been set back to factory default.
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC,
AT49LV002-70TC (IC
817 ) at DSP board (Denon P/N: 262 3010
006).
Denon avr 592 no sound
Hi, First of all check all the speakers. Maybe all the speakers gone out because of the loud blast. Also check in the tuner mode. Is there is any sound. If there is some problem in the avr then it will show the fault and will go into protection mode. You can check the speakers with a battery from any one of the remote. Take the leads of each speakers and connect the lead to the battery terminals. If the speaker is ok then it will make a small cracking sound each time when you connect its wire to the battery. Ajin
Unlock the sound settings lock
On my Denon 1913 under the general setting in setup is a setup lock option. Mine is set to "OFF" . You need to find a similar option on your receiver and be sure it's set to "OFF".
