20 Most Recent
Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo Questions & Answers
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
9/30/2019 2:19:52 AM •
Panasonic...
Answered
on Sep 30, 2019
My panasonic tv dvd vvcr
Return the universal remote,if all ur tv universal codes of ur tv on the owner manual,don't work.Try website like Remotes.com to buy the tv original remote or very close capatible to it.Yes,it cost double even tripple the prices of any niversal remotes,but these remotes are 100% it will work with ur tv,because it the same or compatible as a orginal remote would.
1/5/2014 10:50:02 PM •
Panasonic...
Answered
on Jan 05, 2014
Panasonic tv, vcr, dvd combo gets black rectangle
There should be a closed caption button on your remote control. You will want to go into the CC settings and turn off the TEXT mode as that is whats causing the black box to appear. Please take a few moments to rate my answer.. Thanks..
11/26/2009 5:44:28 AM •
Panasonic...
Answered
on Nov 26, 2009
DVD player
Its posibal your dvd not rogins the informations is tiping of dvd
12/24/2008 3:42:12 AM •
Panasonic...
Answered
on Dec 24, 2008
Audio
how to change the sound siestem from 6.0 to 5.5
11/10/2008 5:41:06 PM •
Panasonic...
Answered
on Nov 10, 2008
Remote code
Some remotes, such as the Sony RM-VL600, have a learning function that will "learn" the code for your set. I used one for my combo unit, and it worked OK for the TV functions, but I couldn't get it to work for the DVD player.
7/12/2008 1:55:53 AM •
Panasonic...
Answered
on Jul 12, 2008
Codes
i need the answer to! someone please post!!
3/28/2008 4:51:29 PM •
Panasonic...
Answered
on Mar 28, 2008
Horizontal line on screen
The most common problem would be a bad solder joint on the vertical drive IC. It could also be a bad solder joint on the flyback transformer, as it supplies voltage to the vert. stages. If you disassemble the set, please be careful not to get shocked. Discharge the high voltage stages as a precaution.
Geno
2/26/2008 9:11:37 PM •
Panasonic...
Answered
on Feb 26, 2008
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
8/6/2007 4:42:02 AM •
Panasonic...
Answered
on Aug 06, 2007
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
5/4/2007 8:55:56 PM •
Panasonic...
Answered
on May 04, 2007
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
