20 Most Recent Denon AVR-1907 Receiver Questions & Answers
0answers
Has power but keeps switching to standby
Disconnect all speakers at the receiver and turn it back on, if it stays on post a comment and I will help you troubleshoot further. If it still cuts out, it needs to go to service for repair. Hope this helps.
2/18/2016 12:34:54 AM • Denon AVR-1907... • Answered on Feb 18, 2016
8answers
H/p input on
I had a similar problem and solved it by simply blowing in the headphone jack (h/p input).
2/25/2015 3:17:34 PM • Denon AVR-1907... • Answered on Feb 25, 2015
No power ; no display
sounds like you might have a bad power transformer.
8/8/2014 2:46:10 PM • Denon AVR-1907... • Answered on Aug 08, 2014
I have an AVR-1907 that powers on but shuts off
Sounds like an overload. Make sure it's getting enough air, no shorts, and using speakers with compatible impedance.
If you press and hold down the power button long enough it might reset it...up to 15 seconds I think.
5/13/2014 9:16:06 PM • Denon AVR-1907... • Answered on May 13, 2014
Ext in problem
if you are using the ext in then it has to be something wrong with the setup from the pc. The receiver does nothing to the ext in input except amplify it and put it out to the speakers.
1/14/2014 2:57:32 PM • Denon AVR-1907... • Answered on Jan 14, 2014
I have sound with AM stereo, but "no" sound with FM stereo
Have you connected an FM antenna to your AVR-1907? This is a co-axial socket on the back marked 75 ohm.
12/10/2013 10:07:09 AM • Denon AVR-1907... • Answered on Dec 10, 2013
Using monster
Hi, You will need to go into the menu of the AVR to change a few settings. To get into the menu -
  1. Make sure you are on an input of the TV that is connected to the COMPONENT VIDEO output of the AVR (I imagine you already have this hooked up)
  2. Using the Denon remote that came with the 1907, filp it to the back side and open the door that covers more buttons.
  3. Press the System Setup button
  4. Go into the AUDIO SETUP
  5. Make sure the DIGITAL INPUT ASSIGNED is set to none for the audio input you wish to use for the PS3.
  6. Going back a menu to VIDEO SETUP, make sure that the COMPONENT VIDEO you are using is assigned to the AUDIO INPUT you are using.
That should fix your problem. If you need more clarification or this did not work feel free to post that on this question. Good Luck
9/19/2013 12:11:36 AM • Denon AVR-1907... • Answered on Sep 19, 2013
RESET
6/23/2013 4:46:42 AM • Denon AVR-1907... • Answered on Jun 23, 2013
Why do i have to power on and off my times with my denon receiver before it connects/
That is called the protection mode, Because of a internal problem with the amp, That is causeing it to over heat, End shut down,
12/3/2012 12:50:55 AM • Denon AVR-1907... • Answered on Dec 03, 2012
Denon 1907 power light blnks red
You have a bad "Driver:" or Power transistor in the amp....I usually replace the two power amps and the driver amp/amps at the same time. The pairs are usually matched, and since one interacts with the other, a bad driver will weaken the power amp pair, and vice versa...The overload is the transistor breaking down 9which tends to generate excessive heat), Then the thermistor on the amp pair heatsink senses this condition and shuts the amp down. (NO - replacing the thermistor eill not generally solve this issue, especially since the thermistor qwill survive a temp rise well above what the tranisitor pair will).
7/25/2012 4:00:12 AM • Denon AVR-1907... • Answered on Jul 25, 2012
Denon AVR-1907 Receiver Logo
68 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
reset
  • Audio Players & Recorders
