20 Most Recent Sony KDE-50XS955 50 in. Plasma HDTV Questions & Answers
What's wrong with it?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/
11/20/2015 6:06:01 PM • Sony KDE-50XS955... • Answered on Nov 20, 2015
Shuts off in 10 sec
mayble the ir remote panel at the back
2/26/2014 5:19:16 PM • Sony KDE-50XS955... • Answered on Feb 26, 2014
Pink Screen
check all your cables & connections & connections at I/O ports; possibly I/O PCB
11/30/2013 6:55:37 AM • Sony KDE-50XS955... • Answered on Nov 30, 2013
We just got a new
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
9/8/2011 7:40:44 PM • Sony KDE-50XS955... • Answered on Sep 08, 2011
Have KD- XS955 50 inch.
Component problem. A defective component on the power supply circuit causes these symptoms ma'am/sir. You need an electronic servicing technician to do the work.
5/26/2011 3:32:32 AM • Sony KDE-50XS955... • Answered on May 26, 2011
TheTV made a loud pop
You probably blew up a capacitor. Unplug the television and open up the back. Check for bad caps. You'll probably find a puffy one. Check the fuses to see if they're blown. If you find a blown fuse, start looking for bad diodes or a bad transistor. If you don't know what I'm talking about then don't ruin a good television set by poking your nose inside and blowing something else up or end up zapping yourself when you touch the wrong thing. Take it to a professional and get it fixed. Good luck.
4/24/2011 4:19:54 PM • Sony KDE-50XS955... • Answered on Apr 24, 2011
Powers on picture for about 45 seconds then powers
One of the fans are not spinning. Take back off and clean the fans and/or replace if necessary.
12/3/2010 10:08:57 PM • Sony KDE-50XS955... • Answered on Dec 03, 2010
I do not have a remote. Will a universal work?
Yes a universal will work for the TV. You will not have all the funtions with a universal though. You should be able to order a new remote from the manufature though.
Good Luck
9/30/2009 12:28:04 AM • Sony KDE-50XS955... • Answered on Sep 30, 2009
5answers
4 BLINKS ON KDE-50XS955 ...
4 blinks means Digital 5Vdc output voltage excessive or
too low.
Usually the power board. Also possible because of an abnormal power draw from B Board.
Test the following:
Power Supply Output Test CN1/pin 9 / 10
B board is the load - Test CN101.
To identify parts and components purchase service manual and follow schematics on service manual.
Parts and service manuals can be purchased from one of the following:
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Manuals and schematics.
ManualsParadise.com The best source of repair manuals
Replacement Parts: Plasma TVs, LCD TVs, Appliances | ShopJimmy
8/21/2009 4:33:27 PM • Sony KDE-50XS955... • Answered on Aug 21, 2009
Fails to start up
Without being able to see the TV or take measurements when it does not turn on, my best "guess" would be the A2U board, which has most of the power supply components. This is only a guess, you really need a tech to take some measurements when it doesn't come on. I would like to get in touch with you to have you check some items using the original remote control. Do you have Yahoo messenger?
12/16/2008 9:19:10 PM • Sony KDE-50XS955... • Answered on Dec 16, 2008
2answers
Tv prob
There is a sleep setting, similar to a snooze butting on an alarm clock, and it can be found in the Time Menu.  Just turn it off, and the set should work fine.
Good luck.
6/1/2008 6:25:28 AM • Sony KDE-50XS955... • Answered on Jun 01, 2008
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
3/19/2008 7:45:26 AM • Sony KDE-50XS955... • Answered on Mar 19, 2008
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 19 hours ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered 2 days ago
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
Sony KDE-50XS955 50 in. Plasma HDTV Logo
Popular Tags
28 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
not remote will universal work
  • Televison & Video
