Quattro 40, 18" Catcher and mulcher
Find the model # and type on the crown of the pull started (there stamped in.
Go to Briggs&Stratton Parts
SOURCE: I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
SOURCE: my briggs and stratton 550 series lawnmower will not run
Could be float in carb.sticking.Take carb off & apart.Put float in water to see if it floats.Check float by shaking next to ear.If you hear any sound,you need a new float.
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
SOURCE: pull cord wont pull,briggs 500 series
Pull the spark plug out and see if it isnt hydro locked. Someone might have overfilled the oil or the carb float may have stuck open and filled the intake with gas!
If the recoil is still stuck you can remove it from the mower and try it without any load on it. Still stuck? The unit might be rusted solid!
You can spray a little penetrating oil into it but be careful.....the oil will soak the pull cord which should be cleaned and degreased immediately following using the penetrating oil.
HEAD OFFICE - NEW ZEALAND
Masport (NZ) Ltd
P.O. Box 14-349, Panmure
Auckland 1741
New Zealand
Phone: ( 064 )( 9 ) 571 1200
Fax : ( 064 )( 9 ) 571 5864
Website : www.masport.com
Email : [email protected]
PARTS manual is here:
http://www.masport.com/LinkClick.aspx?fileticket=xZ1hKEx%2FYSc%3D&tabid=655&mid=1460
Thanks for choosing Fixya,
Kelly
