20 Most Recent Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block Questions & Answers
https://www.manualslib.com/
Try this site for your manual.
Briggs &... | Answered on Apr 03, 2019
This site has a lot of manuals Try it
Try this site for the manual you need.
Sounds like a fuel problem. Check the lines and filter.
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
Briggs &... | Answered on Aug 11, 2018
My first thought would be the screw that holds the carb bowl. It has a little orifice and 4 holes evenly spaced around the base of the screw and it is vital that all holes and orifices are completely free of gunk and trash or varnished gummed up stuff. That must be cleaned. I use B-12 Chemtool carb jet spray. I suggest using compressed air as well. An old guitar string (G,B,or E strings) works well but do not make sharp bends with the wire! It will snap off at the right time and poke your finger. This case calls for a little common knowledge Lol. And supposing the main jet has been sprayed and blown out. Main jet is the tube with many evenly spaced holes around it. Some are removable. I clean my carbs using a welders torch tip cleaner files. Never ever ever force a wire too large in these orifices and holes. Always use the nxt smaller size wire.
Briggs &... | Answered on Jun 26, 2018
try PartsTree.com
Briggs &... | Answered on Apr 11, 2018
SearsPartsDirect they may have one you can download if not try PartsTree.com
Briggs &... | Answered on Feb 08, 2018
Check the spark plug is clean
Briggs &... | Answered on Oct 15, 2017
Does the engine want to bog down when you move the throttle? Or does it do absolutely nothing?
If it bogs down when you try the throttle, It could be:
water in the gas
bad or distorted diaphragm (if no float)
stuck needle valve
stuck float
I’m happy to help further over the phone at https://www.6ya.com/expert/karl_14766549451f8563
Briggs &... | Answered on Jul 19, 2017
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Briggs &... | Answered on Apr 02, 2017
you don't. if it spun on the shaft then you have to replace the cam.
Briggs &... | Answered on Jan 03, 2017
.030 or 76 MM
Briggs &... | Answered on Jun 26, 2016
ethanol additive in gasoline causes deterioration of fuel system parts, especially primer bulbs. Needs to be replaced...relatively easy for mechanically minded or bring to dealer. Check Amazon for parts...they are cheaper than most dealerships.
Hope this helps....
Briggs &... | Answered on May 01, 2016
check the fuel system clean the carb .
Briggs &... | Answered on Apr 20, 2016
Hi Susan, The link below is a short youtube video on how to test a briggs and stratton coil, I hope this helps...CHEERS..
https://www.youtube.com/watch?v=a9N38-kOi7g
Briggs &... | Answered on Mar 29, 2016
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
443 questions posted
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
JOHN LAPIER
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Garden
Most Popular Question
fuel leaks out primer bulb nipple small
  • Garden
