Hello
I want to know where is the jumper in HP nc6120 motherboard, in order to reset bios password
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
HP/Compaq/Acer InsydeH20 Bios Password Service
with 8 digit HashCode
Support model: Compaq CQ40, Compaq CQ45, HP DV3, HP DV4,DV5....
We can help you remove this password.
You just entering 03 times wrong password, then your screen will show 8 digit code number (view below image):
Let's me know your 8 digit code and Model Name ( [email protected])
GO TO >> Master password - Bios Password
On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual cmos battery.
By the processor - Some manufactures will place the jumpers by the processor of the computer.
Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location. If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard. If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
hope this helps
