MY VACUUM ISN'T PULLING AS STRONG AS IT USED TO SO I THINK IT NEEDS A NEW BELT. I CAN'T FIND THE MANUEL ON IT SO I NEED SOME INSTRUCTIONS ON HOW TO CHANGE THE BELT. I DON'T WANT TO BREAK MY VAC. CAN SOME ONE PLEASE INSTRUCT ME ON HOW I SHOULD CHANGE THE BELT PLEASE. TYPE VAC: EUREKA THE BOSS WHIRLWIND LITE CYCLONIC POWER CANISTER TYPE VAC. THE HANDLE IS DETACHABLE TO CLEAN IN THE CORNER WITH A SMALL EXTENSION.
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Most times that burning rubber smell is the result of a worn out rubber drive belt. This belt is used to drive the rotating beater brush in the head of your vacuum. When the belt gets old and loose, the drive pulley starts to spin in place and heats up the belt instead of turning it properly.
To fix this issue, just unplug your vacuum, then disassemble the bottom head in order to access the beater brush drive belt. Remove the old belt, then replace with a new one, and then reassemble it. The old belt will probably have a part number on it so you know which type to buy, or you can just look up your vacuum model number online to find the correct replacement part for it.
Since you did not provide your vacuum's exact model number, here is a link to a short video which demonstrates the basic belt replacement procedure for a generic vacuum cleaner:
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Please take time to rate me
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.Turn it over and wipe all the black residue off the bottom of it.------Either the brush is getting clogged and blocked by dirt, hairs etc etc and that needs to be cleaned or the brush bar motor is got faulty and needs to be replaced.-------You can yourself replace this motor,m if its not running.-------To get instructions to disassemble the vacuum and replace the motor, click this link below :---http://howtobyme.blogspot.com/2011/08/brush-not-turning-on-dyson-ball-dc24.html-----------This will-help.Thanks.Helpmech.
I think this is a terrible answer.. but after researching everywhere on how to change the belt, most answers were to look up the owners manual. So I looked it up online. this is all it has on changing the belt: "Belt maintenance The brush belt is designed to last the useful life of the cleaner when used according to all instructions in the user guide under normal household conditions. If you feel that it needs to be checked or replaced, call BISSELL Consumer Services or visit the website to locate an authorized service center. Do not attempt to disassemble the vacuum foot to change the belt."
Have you ever replaced the belt? That is most likely the reason that it is not picking up like it used to. You are actually supposed to change the belt yearly. Here is the belt you need and the manual which has instructions:
You can fix it easily. All you need to do is change the belt and you'll
be good. Here is a link to the belt you need and the manual which has
instructions.
This problem has unfortunately plagued many owners of this vacuum including myself. I'm not an expert on vacuums, but through some experimentation I found a workable solution. You can first try a new belt, but that will unlikely solve the problem. For some reason the drive shaft becomes too slick for the belt and so the shaft will spin but it won't catch the belt. I wrapped a piece of electrical tape around the shaft for some added friction, and voila, everything started working again. Eventually, the electrical tape shredded a bit and fell off, but it left enough residue on the shaft to retain friction. I know this sounds like a real hack job, but if you've given up hope on everything else, or you can't return the vacuum, it's worth a shot.
First you need to press the foot pedal for the height adjustment all the way down to lift the front of the vacuum off the floor. On the front top of the vacuum where the LED lights are is a cover. That section will lift up by lifting just below the LED's. Once it's lifted up there are some visual instructions, but here's what they are saying. The little circle on the front divided with the word KIRBY is the belt release. The section of the circle with the word on it will pull out. Like a wind-up flashlight it will turn from lining up with the green arrow counter clockwise 360 degrees and lining up with the red arrow. This takes a little pressure to turn it. Now just above this circle, under the LED bonnet, there is a lever that holds this whole front end on. It must be turned also counter clockwise to remove and front then slips off. The reverse would be used to put the beater roller portion back on. Also this would be the way to slip on the hose attachment to **** through it instead. I hope this is a little clearer.
Belt needs to be replaced, it has stretched to the point that under load, it won't turn the brush roll like it should, so I would advise replacing the belt. And while you are doing that, check the brush roll and make sure the ends turn freely, if not, then replace it also. Then check the dirt inlet while you have the brush roll out.
