20 Most Recent Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Questions & Answers
How to replace switch on dirt devil m087305
Hi there! The M087305 has an on/off pedal that controls the power. We do not recommend you repair this part. You can take the vacuum in to your authorized service center for repair. I have included a link that you may follow to locate the closest service center to your zip code. If you need more assistance please reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil. Service Center Locator
6/22/2015 5:27:40 PM • Dirt Devil... • Answered on Jun 22, 2015
2answers
Why doesn't my dirt devil vision turbo have any suction through the hose yet there's good suction at the hose connection to the canister?
The hose is probably blocked. If possible reverse it (put the intake of the hose on the canister connection) that should suck out the obstruction. If that fails try to carefully push a broom handle into the hose, preferably from the end that connects to the canister. Put the hose back on normally and see what happens.
5/22/2015 2:50:37 AM • Dirt Devil... • Answered on May 22, 2015
2answers
Need to change the belt
Here is a link to the belts you need and to the manual which has instructions:
Dirt Devil Vision Turbo Replacement Belts
Download the Manual (PDF)
2/21/2015 4:59:16 PM • Dirt Devil... • Answered on Feb 21, 2015
How to clean filter type f51
Hi! The F51 filter can be rinsed to clean. Hold the pleated filter under running water to rinse. Do not use any soap or detergent. Allow filter 24 hours to air dry before replacing in the vacuum. The foam filter can be washed the same way. The filter should be replaced about once a year. I have included a link where you may go to purchase a replacement filter if needed. Thanks! F51 Filter
10/23/2014 1:32:54 PM • Dirt Devil... • Answered on Oct 23, 2014
0answers
Machine spits dirt out the back
Clogged unit
2/28/2014 8:13:16 PM • Dirt Devil... • Answered on Feb 28, 2014
Wont move
Check all the wheels to make sure they spin freely.
1/29/2014 9:24:59 PM • Dirt Devil... • Answered on Jan 29, 2014
0answers
Manual 087300
Be the first to answer 1/26/2014 3:32:00 AM • Dirt Devil... • Posted on Jan 26, 2014Be the first to answer
How do I get a sock out of vacuum hose?
If you have a shop vac you can try putting it on one end of the hose and suck it out. Otherwise just try shaking the hose until it starts coming down. It may take a while but it will eventually come out. I had this happen and had to keep shaking it and hitting the end on the floor and it eventually came out..good luck!
12/15/2013 10:14:26 PM • Dirt Devil... • Answered on Dec 15, 2013
Www dirtdevil com
6/20/2013 9:32:13 AM • Dirt Devil... • Answered on Jun 20, 2013
2answers
My dirt devil has no main suction
You need to go a bit deeper in the unit to get what is clogged. it is most likely clogged on the inside of the unit. Take off the back and remove the inner workings following the path of the suction. Not hard to do just sucks.
1/24/2013 3:40:52 AM • Dirt Devil... • Answered on Jan 24, 2013
Roller doesn't turn
I can help. I own a Vacuum store in Hallandale Florida. You can google me at 954-454-3594. I can help diagnose over the phone to resolve the issue.
1/15/2013 10:19:45 PM • Dirt Devil... • Answered on Jan 15, 2013
0answers
Vacumm just shut off
It could be that you sucked up a piece of paper or plastic which got stuck in the hose and the vacuum just shut off due to over burn protection. Check the hose if it is stuck. You can drop a penny and see if it glides and comes from the other endMost good vacuums these days come with a tiny reset switch. Just press it with a pointed needle or pen tip. It your vacuum shut off due to protection feature, it should come back to life.
5/25/2012 10:18:06 PM • Dirt Devil... • Answered on May 25, 2012
I don't know how to
Take all the screws off the bottom to access the beater bar than slide out (belt will also be right there ) just slide a new one on......
11/19/2011 1:37:18 PM • Dirt Devil... • Answered on Nov 19, 2011
0answers
0answers
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
96 questions posted
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dirt Devil Vacuums
  • Dirt Devil Vacuums
Most Popular Question
get sock out vacuum hose
  • Vacuums
