20 Most Recent Dyson Ball DC24 Bagless Upright Vacuum Questions & Answers
2answers
Why does my dyson vacuum cleaner tip over when using the wand
Hi there,Your Dyson should not tip over while you're using the hose and wand. If it seems to be doing this, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), as we may be able to offer some helpful advice on the best way to use the machine.Best wishes,Jack Dyson Online Customer Supporthttp://www.dyson.com/
2/18/2021 5:39:06 AM • Dyson Ball DC24... • Answered on Feb 18, 2021
Empty hatch on canister will not open
Sometimes on mine, the red clip that's at bottom of canister doesn't always click back into place, so when you press the red button, it just slides out missing the catch. How i resolve this i pressed down the red button so the clip was sticking out, then with my thumb pressed it in, and it clicked back into place, now been fine with each empty.
12/27/2020 11:27:01 AM • Dyson Ball DC24... • Answered on Dec 27, 2020
2answers
Dyson ball dc24 the brush bar is not turning
Hi its Darran at Dyson.
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning.
If this doesn't rsolve the problem, please contact our Helpline on 0800 298 0298, between the hours of 7am - 10pm, 7 days a week.
Kind regards
Darran
Dyson Customer Service
5/9/2019 3:06:04 PM • Dyson Ball DC24... • Answered on May 09, 2019
3answers
How to stretch the dyson ball vacuum hose
Hi there,I'm sorry to hear you're having difficulties with your Dyson. Due to the machine's very powerful suction, it's normal to experience a certain amount of resistance from the hose in use. However, you may find that stretching out the hose to it's fullest extent with the machine switched off, while someone else holds the machine in place, helps loosen it up a little.If you've tried this and are still concerned, please get in touch with us directly so we can provide further assistance. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).Best wishes,Jack Dyson Online Customer Supporthttp://www.dyson.com
3/11/2019 6:11:10 AM • Dyson Ball DC24... • Answered on Mar 11, 2019
2answers
Dyson dc24 roller brush stopped spinning
There are two switches to check. The push button switch on the handle and the other one that turns brush roll on when you recline the handle back.
2/3/2018 7:36:03 PM • Dyson Ball DC24... • Answered on Feb 03, 2018
Hi I have a Dyson DC24
You can youtube how to remove hose or order new hose assembly.
10/7/2017 4:40:06 AM • Dyson Ball DC24... • Answered on Oct 07, 2017
0answers
DC24 loss of suction when upright
blockage in the yoke or side pipe, remove head, use a finger to feel for the paper thats stuck inside, and remove side pipe to clear from the top of the yoke 5 min fix
8/24/2017 1:25:54 AM • Dyson Ball DC24... • Answered on Aug 24, 2017
I have a dyson roller
Hello, this is Ava with Think Crucial. There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance. First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing. While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all. You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dyson I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
4/30/2017 12:13:01 PM • Dyson Ball DC24... • Answered on Apr 30, 2017
Dyson vacuum power cord
Hello, this is Ava with Think Crucial. You may purchase your Dyson Power Cord from us using the link provided below. Dyson DC07 DC14 DC17 DC18 DC25 Replacement Power Cord Part 905449 02 You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dyson I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
4/30/2017 11:20:19 AM • Dyson Ball DC24... • Answered on Apr 30, 2017
Dyson dc24i brushes do not work
3/5/2017 11:38:12 PM • Dyson Ball DC24... • Answered on Mar 05, 2017
I cleaned the brush head to my Dyson 24 and all was well but now the brush roller does not spin. Have pushed reset button several times. Can feel it vibrate but not engage.
The belt and clutch are probably worn or broken. Instead of a normal brush roller belt like most vacuums have, Dyson designed these with a plastic clutch between the motor and brush roller, so you can turn the brush off for hard surfaces. The belt from the motor to the clutch is replaceable, but it is the belt least likely to wear out or break. The belt to the brush roller, which is the one that takes all the beating and encounters all the dirt and grit is plastic welded into the clutch and cannot be replaced. You have to replace the entire clutch when that belt goes. On a normal vacuum, this is a $3.00 to $5.00 repair. On a Dyson, the part is around $25.00 retail, and you have to tear half the vacuum apart to get to it. You don't need much in the way of tools to repair it, as most of the vacuum simply snaps together, although you have to take care that you don't break the plastic parts getting them apart. You do need a torx screwdriver to remove the clutch housing. I've done two of these in the last week, both with the same issue.
1/7/2017 8:23:31 PM • Dyson Ball DC24... • Answered on Jan 07, 2017
Why does the roller not go round on my dyson DC24
Hello, this is Ava with Think Crucial. There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance. First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing. While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all. You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dc24 I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
12/18/2016 9:23:55 PM • Dyson Ball DC24... • Answered on Dec 18, 2016
I need a operating manual
Hello, this is Ava with Think Crucial. You may check the Dyson DC24 manual by clicking the link below: Dyson DC24 User Manual You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dc24 I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
12/14/2016 1:17:07 AM • Dyson Ball DC24... • Answered on Dec 14, 2016
How do I empty the hvc-22
If you are meaning the DC24, like your post seems to be tied to, the manual can be found here: https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC24_Manual.pdf and the pictures for removing the canister and triggering the lower empty-hatch are on page 3 under 'Clear Bin Emptying'. Good Luck!
10/31/2016 7:45:54 PM • Dyson Ball DC24... • Answered on Oct 31, 2016
Dc24 brush not turning
It may need to be cleaned. Hair can get caught in the brush and can make it hard for the brush to turn. Try cleaning it out. If that doesn't work you can always contact dyson's support to see if they can replace you brush head. Here is the website to get support from dyson. http://www.dyson.com/support.aspx
8/6/2016 7:26:02 PM • Dyson Ball DC24... • Answered on Aug 06, 2016
Dyson DC 25. The roller brush will not engage. What can I do.
It may need a new belt, a new power nozzle motor or the whole nozzle housing needs replaced. It also could be the power nozzle is not getting power from the vacuum which could be a short or bad switch. There are many areas that one or more could be causing the problem. First determine if the problem is in the power nozzle itself or the vacuum then eliminate the possible causes one at a time until you determine the cause. It's much more difficult to find the cause if there is more than one issue causing the problem.
4/12/2016 2:20:27 AM • Dyson Ball DC24... • Answered on Apr 12, 2016
Dyson Ball DC24 Bagless Upright Vacuum Logo
860 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
button brush off doesnt pop back up
  • Vacuums
