SOURCE: Won't recognize color ink cartridge
This is a common problem with Kodak 5000 series and ESP series printers.
Check the silver contacts on the ink cartridges for small scratches in the center. The scratches indicate that the ink cartridges have made contact with the appropriate connections in the printer. If no marks are visible, the cartridge was not seated properly. If the contacts look ok, you'll have to call Kodak again. It's highly likely that the recertified printer you received was returned for the same problem. If you point out the fact that you are experiencing the same problem for the second time, you may wind up with an upgrade to an ESP5. Don't accept another printhead replacement as thiat will not resolve the problem.
SOURCE: Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
SOURCE: Just replaced both ink cartridges on Kodak ESP 3.
silly question, you remembered to remove the plastic film off the connectors right? i realize you did 2 different cartridges but hey sometimes thing get messed up lol. it may be a faulty cartridge, you should be able to return it if that's the case. the only way to know for sure is to take it back and get a different one. if that's the case problem solved, you could always power down the printer completely after installing the cartridges and rebooting it
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
