20 Most Recent
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Questions & Answers
Printhead Error 3802
3802 Mean Printhead Failuer
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it that again for (5x)
Tell this to kodak support
And tell the troubleshooting steps you did.
Printer not activated, error code - 20
You may face the "
Error code-20′ with your printer installed in your Windows 7. The cause of the display of "Error code-20′ may be due to the following reasons. The desired printer may not be the default printer for your prints, issues with the USB composite device, and file missing or file corruption with the printer software supplied by your original equipment manufacturer.
My Kodak ESP 3250 won't
Try initiating the scan from the computer, once you plug in the USB cable into your computer, go to My Computer, right click the sanner (should be called something along the lines of KODAK ESP.....) and press scan, then click which program you'll use to scan it, I usually do the Microsoft one, Good luck!!
How to clean print heads on kodak esp-3
Press and hold Cancel and Copy button simultaneously until the
On/Off light flashes green. you will see a flashing green on your printer it means its now cleaning the printhead
You can also clean a printhead using computer., first you need to launch the Home center software On your computer and on the uppr right corner of the windows of the software click help icon(?) then go to maintenance and under maintenance you should see the clean printhead. GudlucK!
Kodak printer will not print
Hi , i have been using avery templates and label paper at work for ages and always printed off without problems on my lexmark . I bought a Kodak however and all of a sudden I could no longer print off my labels , when I put paper in it just came out blank and said paper wrong size .I could not find any solutions at all and was tearing my hair out . I just kept trying different things and all of a sudden I changed a setting and it worked perfectly.When you go to print your label change the ' scale to paper size ' function to A4 and then it will print.hope this helps
Errors on my Kodak ESP 3250
error 3501: STATUS_ERROR_UNIT_OPENED_WHEN_IDLE. You probably had it open when you inserted your cartridges.
Error 3502: STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY. You must have inserted some shortly after you turned the printer on for the first time so don't worry.
Error 3609: STATUS_ERROR_UNIT_OPEN_WHILE_PRINTING. This is also another basic function on the printer.
I would recommend not looking at the errors on a printer test page as they show all errors that come up on the printer, even if they are not important.
My Kodak ESP3 acts like it runs out of ink...faded
There are many situations by witch a printer can act that way. Remove all cartridges after turning off the printer or unplugging it. On each cartridge are metal pins or contacts, usually gold colored. Take a Qtip saturated slightly with rubbing alcohol and rub (clean) off any residue, pat dry and let air dry. Do not touch with you fingers as it leaves film on the contacts. Reach inside the cartridge well and you will see corresponding contacts. Do the same as you did with the cartridges. Visually look at the contacts to see if any old ink may still be present. If so, clean again. Now you have a good connection between the cartridge and the printers contacts. Replace and see if that corrects the problem. Generally, it is a good idea to use brand new carts, but if the previous carts are full, use them anyway. When you turn the printer on, go through the head cleaning and alignment procedure first before you try and print a page. See if this fixes the problem.
I have a brand new kodak esp 3200 all in one
Brand new ? take it back to the store ? ask for a replacement but pick a different brand ,maybe a small $ adjustment might be necessary depending if you pick a more or less expensive brand .
