Computers & Internet Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
USB cable to connect JVC camcorder to PC
My JVC camcorder Model No. GR-DVL310U, to connect to USB PC port, needs a cable. I want to get the cable. Inform whwere to buy it.
Anonymous
Level 2:
  • Expert 45 Answers
  • Posted on Apr 11, 2009
Anonymous
Expert
Level 2:
Answers
45
Questions
Helped
19290
Points
136
Hi there, found the following cable on ebay - the picture clearly shows both ends so you can verify that it will plug into your camcorder.
http://cgi.ebay.com/For-JVC-Camcorder-Mini-DV-to-PC-Computer-USB-Lead-Cable_W0QQitemZ350183177004QQihZ022QQcategoryZ139969QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hi, I have a JVC GR-D750AA digital video camera. I do not know how to download the things recorded to my PC. I have also bought the USB cable n tried but the camera USB port is not recogned by the PC. I do...
Turn the power switch on your camcorder to "Off." Connect the USB cable that came with the camcorder to the USB port on the camcorder. If you are using the DV cable, connect one end of the cable to the computer first. Put the other end of the USB cable into the USB port on your computer. If you are using the DV cable, connect it to the camcorder. Power on your camcorder. Wait while your computer recognizes the attached JVC GR-D270U camcorder. Typically you will get a pop-up on your screen asking how you want to proceed once the camcorder has been recognized. Open your video editing software, such as Adobe Premiere, Roxie, iMovie or Windows Movie Maker. Import, or capture, the video from the camcorder to your computer using the video editing software. For example, in iMovie you click on "File," then "Import from Camera" to download the movie from your camcorder to the computer.
1helpful
How can I get a manual for my JVC camcorder,model#GR-DA30U. Also how do I get a USB for same camcorder?
JVC has manuals for the GR-DA30UC and GR-DA30US models at
http://books.jvc.com/booklist.asp?Model=GR-DA30U
Neither one of them has a USB port, so there are no USB cables for the camcorder
Oct 20, 2010 • Cameras
Im trying to transfer viedeo from a JVC GR-DVM96 vis usb to mini usb. Do I need to use the dv port?
Hi, connect the cam and PC using 4 pin firewire cable (not USB cable).
Switch on the cam.
Open Windows Movie Maker and import the video from device.
3answers
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
1helpful
Connect old camcorder to new PC
JVC has the support page for the GR-SXM260U here: http://support.jvc.com/consumer/product.jsp?modelId=MODL027120&pathId=25&page=3&archive=true. This camcorder can be connected to a TV with the S-video connection (JVC recommends their YTU94146A S-Video cable) or two RCA connections. If you use an RCA composite cable, you use only one of the two audio connections (white) and the yellow video cable.
To connect this camcorder to a computer, you need a USB video capture device and some type of video capture software. Here are two examples: https://www.amazon.com/Diamond-Multimedia-VC500-Video-Capture/dp/B001FAE8MA and https://www.amazon.com/ION-Analog-Digital-Converter-Composite/dp/B002MT7JFQ .
I hope this helps.
GR D71Ek
any cable should do, have you tried the back of the pc's usb ports?
try another pc?
Download mini DV tapes to my PC?
You need a Fire wire port to download your videos. It works very well
2answers
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
1helpful
JVC GR-DVL310 VISTA DRIVER
Your JVC is a MiniDV camcorder, which uses a Firewire connection for capture. Firewire drivers are standard for all DV camcorders, and built-in on every version of Windows since about Windows 98SE (well, they didn't work very well until Windows 2000).
You still need a capture application to complete the transfer. Most (maybe all) versions of Windows comes with Windows Movie Maker, which is a very basic program, but it can do this.
Normally, a DV camcoder can't be detected by Windows until you have it connected via Firewire, and have it the appropriate mode. On some cameras, this can be play or record (the latter would tranfer live video, or allow recording TO the camera), on others, you need to set the camera to a "link to PC" mode. I currently own Sony and Canon camcorders that both work in the former way, but my first DV camcorder was a JVC, and it did have to put in a "link to PC" mode to be detected by the computer. If you can't find the setting, you might want to check your user manual.
For still photos, it looks like you use a USB connection. I haven't found all the details on this camcorder, but this is likely to be a normal USB "storage class" connection. If so, your camcorder would show up like a disc drive, and you can drag photos over. Vista will support this by default, too.
The other way some older camcorders send photos is to appear to the system as a USB scanner type device. You would need a device driver for this, from JVC.
The user manual would be helpful here. You can get one via download if you don't have it:
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310U
http://books.jvcservice.com/booklist.asp?Model=GR-DVL310UM
2answers
Connect A JVC GR D31 Camcorder to a Computer Via USB 2
Well I'm afraid not the cable don't not come in such of a way either cause they are different type of cable, but what u can do is buy an external fire wire card for yr PC it comes in PCI format for yr desktop PC. because camcorder in these days do not use USB cables due to the cause that fire wire cable is much faster than the USB ones.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
