Http://kitchen.manualsonline.com/manuals/mfg/whirlpool/gb2shdxp.html
It'll have detailed instructions on how to remove the door. Good luck! =]
SOURCE: light clicking sound from outside whirlpool french
Check the fan blade on the fan in the freezer. It could be an object or ice, frost, anything. If this is an Amana Whirlpool, definitely check to see if the fan blade is no longer tight on the motor shaft and has moved forward and hitting the guard in front of it. ( yes, amana whirlpool )
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
SOURCE: want to move whirlpool american side by side
1. If you just need to gain a little space you can simply remove the door handles. They should just lift (or slide) up with moderate force and can be removed.
2. If you only need to move through one door in a building you might be able to open the doors enough to make the unit clear the door you are trying to move the unit through. This would take care.
3. If you really do need to remove the doors, be sure to disconnect the water line at the rear. Then gently snap off the hinge assembly covers at the top of the unit and disassemble the hinge. Be aware of water lines when you are ready to remove the doors.
dwilli10
SOURCE: whirlpool stainless french door refrig...need to
it is much better to remove the complete door instead of handle . there are 4 screws inside that will release the complete door . if your want to do the handle use a credit card and insert it between the handle and door to release . but if stainless it some times leaves marks on door . i always remove the doors as one door is ever and i mean very costly.. mm hope this helps mm feed back pls ..
SOURCE: water accumulates beneath freezer basket
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
