Whirlpool DU930PWSS Stainless Steel Built-in Dishwasher Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher detergent won't dissolve
We just got our new dishwasher, Whirlpool 24 inch built in, model DU930PWSQ this past January. We have a problem almost everytime we use it, the detergent won't dissolve, so nothing gets clean. The gel pack will just sit at the bottom of the washer, sometimes it even looks brand-new still!
And the times that it does actually dissolve, the dishes are never clean.
We've turned up the water temp, but that didn't seem to do anything... any other ideas?
Jeff Meyer
Level 3:
  • Master 423 Answers
  • Posted on Apr 04, 2009
Jeff Meyer
Master
Level 3:
Answers
423
Questions
5
Helped
287469
Points
1081
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Soap is not dispensing. Sometimes the soap dispensing door isn't opening and other times it is but the soap is not dissolved
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
When running my Whirlpool Quiet Partner II, the soap cubes do not dissolve. 99% of the time, they just drop down to the bottom of the dishwasher or onto the silverware bin. I tried liquid detergent, and...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
This dw is not cleaning tea stains off cups. My older whirlpool did so just fine. One issue I see is that the detergent is not fully dissolving and gets stuck in the detergent door or is in a lump on the...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Du1100xtpba The top rack of dishes doesn't get cleaned at all. And when we switched from a powder to liquid detergent (to see if it affected anything) the liquid detergent now stays gooped in it's...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dishwasher is not cleaning
make sure the unit is hooled to hot water.prime sink befor starting the unit check unit in a short time is water still hot? if not check element
D/w doesn't dissolve deterg. & therefore not washing dishes
Do this test:
-Upgrade to a name brand detergent like Cascade or Electrosol.
-Do not over fill the dispenser cup
-Do not place large items near the door/near the dispenser cup.
-Make certain that both spray arms can spin freely after you load the dishwasher but before you close the door to begin the wash.
Please report back what you find, OK?
Gel paks don't dissolve
Before you start the machine make sure the water is hot enough going into the dishwasher. Sounds like the water temp is not hot enough to melt paks or dispenser is not opening.
1helpful
The soap fails to disolve!
Having the dishwasher powder failing to dissolve is a far more common problem recently with the filing economy.  People are trying to save money by buying generic dishwasher powder rather than brand name products.  The ultra-cheap products fail to dissolve because their ingredients include bulk fillers with minerals, etc.
It is possible that the dispenser is failing to open, but that is a generally rare problem except on very, very old dishwashers. Before deciding the dishwasher has failed, go buy a box of brand name (Electrosol or Cascade) dishwasher detergent powder and only use it.
Please report back your results here, OK?  Good Luck!
1helpful
Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
