20 Most Recent Whirlpool 24 in. GU3200XTP Built-in Dishwasher Questions & Answers
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Whirlpool 24 in.... | Answered on Jun 04, 2019
Is this hooked up to a insta hot under the sink? if so, the insta hot could be bad or the line coming from it could be clog meaning that there's no water coming into the dishwasher .
Whirlpool 24 in.... | Answered on Oct 31, 2014
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Whirlpool 24 in.... | Answered on Feb 26, 2014
Try this diagnostic cycle operation to reset.
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Whirlpool 24 in.... | Answered on Feb 16, 2014
1st check for food build up under the filter, just shine a flash light through the holes front left side at the edge of your filter. This area is the water intake for the wash arms.
Whirlpool 24 in.... | Answered on Oct 26, 2013
Whirlpool 24 in. GU3200XTP Built-in Dishwasher Logo
153 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
whirlpol du1145xtpb1 dishwasherr need
  • Dishwashers
