20 Most Recent Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Questions & Answers
More than likely the control panel has failed, this is about a $300 repair on most.
Whirlpool 24 in.... | Answered on Jul 06, 2017
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Whirlpool 24 in.... | Answered on Jun 20, 2017
Hi Cathy, we are sorry for the concerns. We would advise service with an authorized servicer. If you would like to schedule service please email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and model/serial number.
Whirlpool 24 in.... | Answered on Apr 12, 2017
To tell you the truth, I don't even know what model my Whirlpool is. However, I had this same issue. My dishwasher would fill, but it wouldn't spray the water. I could hear it hum, but the motor wasn't going.
After no success finding any ideas online, I had to call out the repairman. Well, 5 minutes and $109 later it was just a simple matter of the motor being stuck. Apparently this is a common issue with GE, but not as common with Whirlpool. Just a seal that gets stuck if you don't use it for awhile (even though there hadn't been any long stretch for me). He reached in/under and turned the motor a bit over a half rotation before it broke loose. It fired up... I wrote the check ... and he left.
He advised me to run the washer on the rinse cycle at least once a week.
Hope that helps someone.
Whirlpool 24 in.... | Answered on Jan 29, 2017
Some leaking around-under-from the door on dishwashers can be traced back to a split in the spray arm. If the lower spray arm develops a split in it, the spray arm can turn too fast, and shoot water directly at things that it is not suppose to spray water at....sprays water at the door vents or edges and can create water leaks. See if thats the problem
Whirlpool 24 in.... | Answered on Mar 05, 2015
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Whirlpool 24 in.... | Answered on Dec 30, 2014
could be the board in the panel for the buttons i had to replace mine was 140.00 but i got mine for 45 off ebay.
Whirlpool 24 in.... | Answered on Jun 12, 2014
I think your dishwasher is in this group. You will have to check the serial number against the range. They specifically check for cracks and holes in the detail.
http://servicematters.whirlpoolcorp.com/dm_safety/8178502a.pdf
Whirlpool Inglis Plastic Tall-Tub Dishwasher Heater Rework #R17365
Whirlpool 24 in.... | Answered on Apr 08, 2014
I have never heard of a water filter for a dishwasher since the water entering your house is clean and filtered and potable. If the water supply line for your dishwasher is clogged you have a different problem where in you must clear it to allow sufficient flow for the machine to fill. If it is restricted it will most likely take longer to fill but it will still operate. If the filler is on a timer then you will not be getting enough water into the machine and must restore adequate flow for it to operate. There is no need to filter water into your dishwasher. People who have water supply problems will get water conditioners for hard water issues and whole house filters for sediment problems. I would get Culligan to take responsibility and fix the problem if they caused it.
Whirlpool 24 in.... | Answered on Mar 11, 2014
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
132 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
dishwasher fills heats water but doesnt
  • Dishwashers
