20 Most Recent
Whirlpool 24 in. GU980SCG Built-in Dishwasher Questions & Answers
FILM ON GLASSES, IS THIS HARD WATER, MIGHT BE MY
Film on the glasses may be a sign that the softener is not working correctly. It may sound silly but check the obvious first, is there salt in the softener brine tank? if not fill it up, allow it to sit for at least 8 hours then manually regenerate the unit. Also check the power to the softener. Check to make sure the bypass is not open. If this stuff is ok then have a local reputable water treatment company come out and test the water hardness to make sure the softener is working correctly. If they say it is not working check the brine draw tubing. The most common failure is from a slight leak in the brine draw tubing which keeps the unit from regenerating effectively. During the brine draw phase of regeneration (2nd step) the softener should draw all the water from the brine tank. Repair or replace the tubing as needed.
Whirlpool Gold Quiet Partner
Dlc737, We apologize for your concerns with your Dishwasher. If you have tried to reset from the breaker and it has not fixed the problem then we would recommend scheduling service. We would be happy to assist you further. Can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to
[email protected]?We would be happy to assist you further.
980 series
Hello.
Take a measuring tape and measure.
Easy,nice and clean also
Good luck
DISHWASHER IS RUNNING BUT NOT FILLING UP WITH WATER
Your problem is probably the water fill valve is defective or it may be the drain valve is stuck open. If it is not filling with water at all, it is probably the fill valve. If it is filling as fast as it is draining, it is probably the drain valve.
If you need more help, post another comment.
Thanks,
Tim
Dishes on the top rack not getting clean
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
