20 Most Recent Whirlpool 24 in. DU1100XTP Built-in Dishwasher Questions & Answers
Whirlpool Dishwasher DU1100XTPB7: The
The pump is most likely bad. If the dishwasher has some years on it, repairing might not be economical. Get some estimates, that will help with the decision to repair or replace.
2/14/2018 12:38:08 AM • Whirlpool 24 in.... • Answered on Feb 14, 2018
Dishwasher stopped mid-cycle
you have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
4/24/2017 2:11:26 AM • Whirlpool 24 in.... • Answered on Apr 24, 2017
Whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
3/4/2015 4:40:45 PM • Whirlpool 24 in.... • Answered on Mar 04, 2015
Mounting my dishwasher to granite counter tops.
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - [email protected] - http://.www.StoneRepairman.com
8/4/2014 4:59:41 PM • Whirlpool 24 in.... • Answered on Aug 04, 2014
0answers
Why does air gap overflow in the first two minutes of the "normal" cycle?
Air gap usually has a valve(sometimes rubber flap) that either is not working or is leaking. Needs to be rebuilt or replaced.
5/28/2014 12:43:03 AM • Whirlpool 24 in.... • Answered on May 28, 2014
2answers
Very bad smell coming from dishwasher
Possibly a water leak underneath or a dead mouse behind the unit.
4/9/2014 4:56:19 PM • Whirlpool 24 in.... • Answered on Apr 09, 2014
LG LDS4821WW dishwasher leaks from front right bottom
your filter or drain are a bit block! mix viniger and baking soda and water and let it sit over night...
3/13/2014 4:09:55 AM • Whirlpool 24 in.... • Answered on Mar 13, 2014
Can't remove lower spray arm
the nut screws off counter clock wise.
1/4/2014 9:49:50 PM • Whirlpool 24 in.... • Answered on Jan 04, 2014
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
286 questions posted
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
dishwasher problem
  • Dishwashers
