Nortel Meridian M7310 Business Phone Nt8b20af W/ Handset Black Logo
A
Anonymous Posted on Jul 22, 2013
Nortel m7310 cant use touch tone
I have a nortel m7310 office phone and when i call out and have to make a number selection (ex. press 1 for english) I cannot do so. I will press the correct number but it wont make the selection. What can i do?
Norm Pearl
Level 2:
  • Expert 108 Answers
  • Posted on Mar 24, 2016
Norm Pearl
Expert
Level 2:
Answers
108
Questions
0
Helped
55258
Points
211
Try Feature 808 before pressing the touchtone digit - it tells the Norstar to send Long Tones to the remote system.
HOW DO I CHANGE THE DATE AND TIME ON A NORTEL T7316E
You should complete programming on a T7316, T7316E, M7310, M7324 phone.
1. Feature **23646
2. Password: 266344
>>>Your password may have been changed by your phone company. Contact them for the password.
3. Select General Admin
4. Select Date and Time
5. Select Time
6. Adjust the Hour, Minute, and AM/PM
7. Press Rls when done
Nortel Meridian M7208 page not working...
Press Feature * 3
press the 5th line key you want to use for paging
enter the page-all code (feature 601-603 as you wish)
2helpful
Hi, is there a way to get a M7310 to recieve a wireless signal? Is there a way to broadcast the signal (like a home wireless phone) to an existing Nortel M7310, my wife is running out of phone jacks in the...
Unfortunatly Nortel system phones cannot work wireless with the exception of thier wireless set which still require a jack/port for the base unit.
3helpful
We have nortel t7316 phones in our office. one
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only
press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
3helpful
2answers
How do I remove the Touch tone/pulse option. This message has recently appeared without knowing how it go there. It was never there before. ''If you are calling from a touch tone phone please press 1 now,...
Sounds like your touchtone gate has been enabled in your voicemail. To disable the touch tone gate enter feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press 1, the display should say TT gate:std chng and ok. press the chng key til it says none and press ok press the rls key when finished.
3helpful
Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
2answers
Norstar M7310- buttons don't produce tone anymore
Its the problem from the system.
Go to the programming of Norstar by Feature **266344 and the password is 266344.
Go to line datd or line and make dialling made as Tone.
It will fix ur problem.
1helpful
Try to cancel a function on my phone
If you are French it means: Appel reçu
If you are English it means: Call Received
To change your phone back to English, goto the set giving you issues
-> press the FEATURE button
-> dial * 5 0 1
This will change your telephone set back to the English language.
2answers
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again! ldtnsj.com
Uniden DSS7955
Dear FixYaTeam,
thank you, but I do not need help anymore. I have been able to get in touch with Uniden Service and was told to go:
menu
global setup
select
dial mode
select
select tone
select
It did work.
Regards
Zdena
Top Nortel Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
