20 Most Recent Nortel Networks T7208 Telephone Questions & Answers
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Nortel Networks... | Answered on Oct 06, 2015
Answer> Manuals: If you want FREE manuals for your device, you must go directly to the maker of your hardware device. Look for their SUPPORT (Drivers and Downloads) and input the required data such as the Make, Mod. of the device in question. They will then take you to the proper section where Drivers and Manuals are located. Here you simply select the option you want to download and install your drivers or open a manual. Manuals often come down in PDF format and require Adobe Reader. Get Reader form http://www.Adobe.com .
Nortel Radio... | Answered on Dec 24, 2013
You would have a better chance of someone being able to help you if you post of the make and model of the radio. Base, mobile etc.
Radio... | Answered Yesterday
Hello Jeff, I was looking for the user manual of your CB Radio Hatadi, to know what fuse it takes and there is no information
I would try the 5 Amp, I would place it and it would work for a long time to the BC Radio, checking that the fuse resists the transmission work
If it does not resist, I would put the 10 Amp and would do the same test
If it does not resist either, then you already have problems with the equipment
If so, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jeff, estuve buscando el manual de usuario de tu CB Radio Hatadi, para saber que fusible lleva y no hay informacion
Yo probar?a con el de 5 Amp, lo colocar?a y har?a funcionar por un rato largo al BC Radio, comprobando que el fusible resista el trabajo de trasmisi?n
Si no resiste, pondr?a el de 10 Amp y har?a la misma prueba
Si tampoco resiste, entonces ya tienes problemas en el equipo
Si es as? busca un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
Radio... | Answered 3 days ago
https://www.cardosystems.com/support/g9x get help from above link, it is user guide and some problem and their solutions.
Radio... | Answered on May 22, 2019
https://www.test-guide.com/free-gre-practice-tests.html
See this site, and if you want to appear you can do practice for examination.
Its better you change the speaker if you need more audio otherwise its ok, at least your hearing the sound.
Raymarine Ray55 Manuals Down Load user manual and reset MMSI according instructions.
Radio... | Answered on May 21, 2019
You have the modulation problem. If you have hand free you connect it and try to send message, if other unit hear you then it mean your microphone has faulty and replace the microphone, the fault is in mic or other circuit from mic input to modulation device which may be any transistor , capacitor or any resistance faulty. Consult with any Radio Service Shop.
You check your radio with other radio very near. If radio is hearing your transmission then it mean that your Radio Power Module not working if very near radio not listening you then your preamplifier and Power amplifier is not working, it mean your Radio Transmitter faulty, only Receiver is working, you consult with any Radio Service shop. One other thing if you have software also check Tx/Rx frequency it must be same for simplex operation.
Nortel Networks T7208 Telephone Logo
1 questions posted
Top Nortel Radio Communications Experts
ka4iup
ka4iup
Norm Pearl
Harrie
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Nortel Radio Communications
Most Popular Question
program t7208 telephone display incoming
  • Radio Communications
