Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Kevin Accola Posted on Mar 30, 2009
Takes almost 2 hours to complete a wash cycle
I own a Kenmore HE3 washer (Model 110.44832200) that we purchased in 2004. Recently we've noticed that it takes almost 2 hours to finish a load of clothes. No error messages show up during the cycle. It appears that clean water continues to run into the wash machine while it's draining and spinning after the wash and rinse cycles. We've also noticed that the bleach doesn't drain and the fabric softner doesn't rinse completely out of its reservoir.
  • Kevin Accola Mar 30, 2009
    I cleaned out the drain a couple weeks ago. There wasn't too much debris in the drain, so I checked the hoses as well. It seems to be draining fine. However, the problem persists.
  • carolyn1234 May 15, 2009
    I have the same problem. I now go to the laundromat to wash my clothes. I talked to the technician who owns the laundromat and he told me there must be a mode switch somewhere on the washer. My washer sits on 1 minute left for at least 30 minutes.
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Mar 30, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
0
Helped
83011
Points
89
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
  • Anonymous Mar 30, 2009
    Have you checked the water pressure on the inlet? Perhaps you need to open the water valve a bit more?
How to Reset a Kenmore Elite HE3 Washer?
Unplug it for 1 hour and plug back in. Hope it works.
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Kenmore HE3 stuck in rinse cycle
my wife was doing laudry with he3 and when it quite the door would not open.tried to restart a new cycle and it would not start.I unplugged the washer and let sit for 2 min.replugged it in and it started to work.I hope this helps you.
1helpful
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
2helpful
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Water standing in tub after cycle has been completed
hi i only fix uk machies but from what you are saying it sounds like the pump may be blocked ,have a look behind the lower panel at the bottem of the machine to see if there is a filter if so try to empty that,hope that helps.
1helpful
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
2helpful
Kenmore washer overheats and shuts off
It sounds like you have a bad timer. Your timer is basically a wheel that turn and opens and closes sets of contacts. Once these contacts go bad, they stick together. Your machine will basicall try to do a few things at once and over heat (hence the reason it works after it cools back down). A replacement timer should be availible from both your local appliance parts supplier and from the manufactures web site.
3helpful
2answers
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Alexander
vince
