Freezers Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nor-Lake t3000 freezer - door HOT
The outside right door of my freezer is extremely hot to the touch. Seems to be freezing just fine, but I just burned my hand on the outside of the door. Help!
  • Anonymous May 11, 2010
    You have a condensation heater malfunctioning if it burned you.
    It should be warm all the time, not hot.
Dennis Boxerman
Level 3:
  • Nor-Lake Master 1,306 Answers
  • Posted on Mar 31, 2009
Dennis Boxerman
Nor-Lake Master
Level 3:
Answers
1306
Questions
Helped
647109
Points
2787
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Freezer door is very hot to the touch on the outside
Hello, their are heat coils in the doors, their maybe a issue with the door heat circuit controls.
Stand up magic cheef freezer unthawing and hot to touch
A freezer can't "unthaw". It can freeze or thaw. I assume your freezer is not cooling properly and is hot to the touch. First try defrosting the interior. Ice buildup will cause the problems you described. Also check the rear of the freezer and clean the cooling coils so they transfer heat to the outside air.
If neither of these things helps, have a professional check your Freon coolant level. You may have a leak.
Kenmore frostless freezer, Model 253-9280413. Food is properly frozen but both outside walls and the top are extremely hot to the touch, particularly the wall to the left of the door which is so hot you...
If your condenser grill is extremely dirty or air flow is not adequeate there will be heat transferance to the cabinet itself.
Highly recommend that you clean your condenser grill (the grill underneath the cabinet) and vacuum as much as you can then blow it out with an air compressor.
2helpful
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
the coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
1helpful
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
3helpful
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
The freezer is extremely hot to the touch on the outsides, but still works well, is this a fire hazard?
The condenser in a refrigeration system does get very hot, actually enough to burn your skin.
Aug 04, 2009 • Freezers
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
1helpful
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Top Nor-Lake Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
