20 Most Recent Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Questions & Answers
MODEL FFU17FC4AW--8 yr old Intermittent leaking
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help Most techs are charging $125.00 minimum for a call out Check out the link above, it mat help diagnose.your issue. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/16/2017 2:51:47 PM • Frigidaire 16.7... • Answered on Dec 16, 2017
Door ajar keeps flashing evan though the door is close
Good Afternoon Friend, I understand the door ajar light keeps flashing even though the door is closed on your Frigidaire freezer, model# FFU17K1CW. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave the model number of your appliance. Hope this is helpful. -Best Regards- WP
7/11/2014 6:20:48 PM • Frigidaire 16.7... • Answered on Jul 11, 2014
Door warning says hi temp, door adjar,light out
Good Afternoon Floyd, I see that you are having trouble with your Frigidaire freezer, model# FFU17K1CW, stating "HI TEMP" and that the door ajar light is out. The model number that has been provided does not show that it has a "door ajar" light. What I recommend would be giving your appliance a hard reset, by either unplugging it or shutting the power off at the circuit breaker for 2-3 minutes. If you are still having trouble with the HI TEMP light showing, please respond back with your model number which is shown inside your refrigerator on either the right or left hand wall so I may better assist you. Hope this is helpful. -Best Regards- WP
4/22/2014 1:46:24 AM • Frigidaire 16.7... • Answered on Apr 22, 2014
0answers
Freezer not cooling
remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
8/6/2013 4:39:07 AM • Frigidaire 16.7... • Answered on Aug 06, 2013
Frigidaire ffu1767fwo (power spike) does not turn on can it be fixed
Hello tom97420 - Was the freezer unplugged during the power outage? It is best to be unplug unit and wait for the power to come back on, turn control to off, plug the unit in and reset control to factory suggested setting. Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the freezer plug is tightly pushed into electrical outlet and not plugged into a GFI. Is the temperature control in the OFF position? Set temperature controls to proper setting suggested by owners guide or set to the halfway point and adjust it up or down as needed. If any suggestions are ineffective, contact a professional to move forward accurately. From what you have described the power loss could have possibly caused a communication problem with the control board, temperature control or wiring harness.
10/26/2012 7:31:35 PM • Frigidaire 16.7... • Answered on Oct 26, 2012
Tempt setting
Hi - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
10/24/2012 7:51:15 PM • Frigidaire 16.7... • Answered on Oct 24, 2012
My compressor is really hot
If the compressor is almost too hot to touch, then you have a concern and need a repair technician. It is normal for the compressor to be a little warm, but not too much where you cannot keep your hand there.
7/24/2012 5:36:29 PM • Frigidaire 16.7... • Answered on Jul 24, 2012
0answers
Everythings runs doesnt get cold
re gas
1/21/2011 1:35:38 AM • Frigidaire 16.7... • Answered on Jan 21, 2011
I have this freezer and it is forming ice on and
Does your freezer seem to be reaching around zero degrees. Second does your freezer have its condensing coil under it or on the back and is it clean. If the coils are not clean it can not disapate its heat effectively and will continue to run. If the coils are clean and the door seal is in good shape doesnt have to be perfect your unit may be low on freon. When a unit first gets low it will run all the time and actually get colder for a while then it will start loosing its ability to cool at all. The ice around the door can be caused because of air leaking in or just excess moisture in the cabinet due to a lot of new items added. I hope this helps
9/18/2010 12:49:17 AM • Frigidaire 16.7... • Answered on Sep 18, 2010
The freezer does not cool
dear sir /madam
please check first your fridge,s compressor is working or not if it,s working and not getting cold then it can be low gas problem so please contact to your freezer maintenance personnel for further action i mean find out leakage and brazing that after fill refrigerant gas , after that i hope your freezer will work good .
hope answer the question
thank you
please vote!
9/15/2010 8:36:05 PM • Frigidaire 16.7... • Answered on Sep 15, 2010
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Logo
Popular Tags
39 questions posted
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
door warning says temp door adjar light
  • Freezers
