20 Most Recent Whirlpool 14.8 cu. ft. Chest Freezer EH150FXM Questions & Answers
0answers
What is the light for
Not sure what light your refering too but>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
4/21/2010 8:33:50 AM • Whirlpool 14.8... • Answered on Apr 21, 2010
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
12/9/2009 2:50:44 AM • Whirlpool 14.8... • Answered on Dec 09, 2009
Chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
7/18/2008 7:58:06 PM • Whirlpool 14.8... • Answered on Jul 18, 2008
Whirlpool upright freezer is working fine but an alarm is sounding intermittently. It sounds different than the high temperature alarm. Can't find codes. What does it mean?
If your Whirlpool upright freezer is working fine but an intermittent alarm is sounding that is different from the high temperature alarm, it could indicate an issue with the door or the door switch. The alarm is designed to alert you if the door has been left open for an extended period or if the door switch is malfunctioning. Check the door seal to ensure it is tight and the door is closing properly. You can also try cleaning the door switch to see if that resolves the issue. If the problem persists, it may be necessary to contact a professional for further assistance.
2/14/2023 6:46:27 AM • Whirlpool... • Answered on Feb 14, 2023
Model UW8FDXB1EX Whirlpool Upright freezer
3/12/2022 12:53:50 PM • Whirlpool... • Answered on Mar 12, 2022
The question i asked has been answered, but is there actual diagrams that i could view to see how it's done?
THIS question is your only question here on Fixya dot com! https://www.fixya.com/users/gregg-j-ajamian You just need a good search query to find stuff like this. Cut out all the extraneous words and use the bare bones. Videos in the link https://www.google.com/search?q=whirlpool+upright+freezer+EV250NXTQ03+remove+the+drain+grommet ..
10/2/2021 5:34:32 PM • Whirlpool... • Answered on Oct 02, 2021
2answers
Hello awesome Fixya Experts! How do I disable the tones/alerts for my Whirlpool freezer (model WZF79R18DM00)?
There shouldn't be any 'jingly tone' at the end of every compressor cycle. You could be hearing something else making a sound after the compressor stops.
3/8/2021 2:35:38 AM • Whirlpool... • Answered on Mar 08, 2021
Model # WZF79R20DW00. Which snowflake is supposed to make it colder?
The larger one
11/30/2020 11:12:06 PM • Whirlpool... • Answered on Nov 30, 2020
My whirlpool upright freezer is beeping every minute
The door switch or door module is defective. or the door is not fully closed
5/10/2019 9:51:02 PM • Whirlpool... • Answered on May 10, 2019
Green light flashing onwhirlpool freezer
http://www.fixya.com/tags/freezer_green_light_flashing/browse/whirlpool
3/13/2019 10:40:02 PM • Whirlpool... • Answered on Mar 13, 2019
2answers
Model EVL201NXRQ05 serial eww4020663 WHIRLPOOL UPRIGHT FREEZER - Freezer which is having ice freeze on the bottom of the freezer. What can I do?
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
1/24/2019 3:41:51 AM • Whirlpool... • Answered on Jan 24, 2019
Model EVL201NXRQ05 Serial EWW4020663 Freezer which is having ice freeze on the bottom of the freezer. What can I do? no plug.
If it’s in floor if freezer, you have a clogged defrost drain. If it’s on inside back freezer wall, it’s a defrost problem
1/23/2019 11:07:42 PM • Whirlpool... • Answered on Jan 23, 2019
My water connection trips power after the water is turned on for a while
The solenoids that operate the ice maker and the water dispenser in the door may be getting water internally. I would put a pressure regulator on the line of the pressure exceeds 30 PSI.
1/23/2018 5:01:53 AM • Whirlpool... • Answered on Jan 23, 2018
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
1/2/2018 2:16:28 PM • Whirlpool... • Answered on Jan 02, 2018
Does a kenmore 5 upright freezer have a thermostat control 9235010
All cooling/heating appliances must have a functioning device to control the rise and fall of temperature. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 11:44:52 AM • Whirlpool... • Answered on Dec 31, 2017
We do not use the freezer on our Whirlpool fridge
The freezer is where the cold air is generated. It knows that is not logical to turn off the fresh food side so it determines that it needs the cold from the freezer side, so it over rides the error and will attempt to start. Turn your freezer on to a mid way setting ans give it a few hours to comply. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 10:11:42 AM • Whirlpool... • Answered on Dec 31, 2017
Whirlpool 14.8 cu. ft. Chest Freezer EH150FXM Logo
6 questions posted
Top Whirlpool Freezers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Freezers
  • Whirlpool Freezers
Most Popular Question
freezer hot outside
  • Freezers
