20 Most Recent Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ Questions & Answers
9abb6871-4eeb-4e17-b4b8-c4bfdafab542.jpgUnplug the refrigerator and remove the contents of the freezer. Then remove air tower and the inside back panel inside the back of the freezer. Disconnect the evaporator fan and replace with the new fan motor. W10189703 Evaporator Fan Motor I am here if you have questionsm Thanks Sea Breeze
Whirlpool 15.2... | Answered on Apr 25, 2013
you read catalogue you find that.
Whirlpool 15.2... | Answered on Mar 26, 2013
I always get my tap valves at www.apdepot.com. The best ones to use are bpv-31 bullet piercing valves, because they are capable of piercing a variety of line sizes, so your not limited to your tap location and find the most accessable spot.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Whirlpool 15.2... | Answered on Apr 27, 2012
check my hints and you will find what your looking for.
Whirlpool 15.2... | Answered on Apr 21, 2011
Same thing happened to me, turns out the compressor when bad at the same time the door was left open, it was pure coincidentally, had nothing to do with the door being left open.
Whirlpool 15.2... | Answered on Jan 30, 2011
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
cxxcxcv
Whirlpool 15.2... | Answered on Sep 30, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Whirlpool 15.2... | Answered on Sep 08, 2010
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Whirlpool 15.2... | Answered on Jun 03, 2010
The thermostat has a thick, bendy, copper or aluminium (non electric) conduction wire that goes from it, to physically connect to the internal metal casing.
When that lead becomes disconnected, the motor can just run, as the thermostat can't get a reading within the range it is designed to look for and control. It just hunts permanently for a reading.
Maybe this is not it, but see if anything came loose when you were storing the machine. If tempted to investigate areas that hold live 115V, always resist doing that and use a licenced electrician.
Whirlpool 15.2... | Answered on Apr 07, 2010
You have to unblocked your drain of the fridge & will work after.
Francois
Whirlpool 15.2... | Answered on Jan 21, 2009
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Whirlpool 15.2... | Answered on Jul 02, 2008
look for a on off switch on the ice maker it is soimetimes hard to find im looking at 1 right now its on the right side in front of the ice maker good luck
Whirlpool 15.2... | Answered on Aug 29, 2007
The door switch or door module is defective. or the door is not fully closed
Whirlpool... | Answered on May 10, 2019
CALL A REPAIR SERVICE LOCALLY . NO DOUBT IT NEEDS FREON AND ONLY PRO'S CAN DO IT FOR YOU
Whirlpool... | Answered on Apr 22, 2019
http://www.fixya.com/tags/freezer_green_light_flashing/browse/whirlpool
Whirlpool... | Answered on Mar 13, 2019
That is a compressor overload chime by the sounds of it. That is why the compressor stops. It is telling you needs attention to stop complete failure of the compressor. Try cleaning fluff out of the compressor coils with a vacuum cleaner.
Whirlpool... | Answered on Feb 06, 2019
The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
Whirlpool... | Answered on Jan 24, 2019
If it’s in floor if freezer, you have a clogged defrost drain. If it’s on inside back freezer wall, it’s a defrost problem
Whirlpool... | Answered on Jan 23, 2019
Whirlpool 15.2 cu. ft. / 430 liter Upright Freezer EV150FXKQ Logo
Popular Tags
22 questions posted
Top Whirlpool Freezers Experts
AJMAL KHAN
Spencer Field
Spencer Field
Level 1 Expert
Steve Allison
Steve Allison
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Freezers
  • Whirlpool Freezers
Most Popular Question
get tap add freon
  • Freezers
