SOURCE: compaq presario 2500 notepad
Well,you already have a DVD burner in your machine, and A DVD ROM refers to memory.. you just need to download the upgrades available at Compaq's website. find out which Cd/DVD burner you have by downloading a marvelous freeware program called Belafrc Advisor, which will list all hardware and sofware on your
computer, compete with versions and access codes. then go to
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=320163&lang=en
which lists all upgrades available for your model. DVD burners stopworking correctly when your non-microsoft burner program becomes corrupt, so be sure to upgrade that. If you have any problems, ask support.
SOURCE: my documents download into notepad as gibberish
Try un-installing the adobe acrobat reader program and reinstalling it. If you have XP it is in ADD/REMOVE programs in the control panel. If you have Vista it is in Programs and features in the control panel. Then go to adobe's website and download the newest FREE Acrobat Reader. Make sure you un-check to get the FREE toolbar, as they are usually junk and cause more problems then they help.
SOURCE: upgrading memory on my Compaq Evo N400C notepad
i have the same Compaq Evo N400c its a ram under the keyboard check there to upgrade it i got Compaq Evo N400c 1gb ram
SOURCE: HP notepad - continueous beeping sound with equal sign characters
If you are getting a lot of = character along with the beeping, this indicates you have a stuck = key and the beeping sound is the keyboard buffer is swamped with the = character. If you can't unstick this key, then you need to replace the keyboard.
SOURCE: windows notepad is in computer code, cannot read
notepad is not meant for viewing formatted html or other help files other than TXT files.
You may have accidentally changed an association.
to change it back for html lets say then right click on the file then use "open with" then "select program from list"
when the list opens scroll down and click "internet explorer" and tick the "always use this application" box
