Olympus LS-10  Digital Voice Recorder Logo
Posted on Mar 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Transferring voice files to PC
I have a problem with transferring data from my Olynpus LS-10 recorder to my PC. When I open My Computer I do not see the drive name and the screen and my LS-10 keeps blinking "Please wait". Also when I put in the SD-card directly into the computer nothing happens. Can you help me? Thanks Jelle Dijkstra Aldtsjerk, The Netherlands
  • nijenrode92 Mar 26, 2009
    I am not, the only software that came with the recorder was Cubase LE4. Do I need other software? It is not mentioned in the manual. If so, how do I get it?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you using the olympus software that came with the recorder?
Tim Babcock
Level 3:
  • Master 2,794 Answers
  • Posted on Mar 28, 2009
Tim Babcock
Master
Level 3:
Answers
2794
Questions
13
Helped
1128428
Points
7249
That software should work. I found a few firmware upgrades that may help you as well. Check this link out:
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1350&os=w
This link is for windows. There is another link for Apple as well.
7helpful
2answers
Recover deleted file?
Here is a list of best data recovery softwares that I have found:
1. uFlysoft
2. Recuva
3. Disk Drill
4. Glary Undelete
5. Panda Recovery
6. SoftPerfect File Recovery
7. EaseUs Data Recovery Software
2answers
I have an rca rp5022 voice recorder and when I attempt to transfer the files over to my computer an error screen pops up stating the file is corrupted and unreadable. I can listen to the file on the...
the files on your voice recorder is actually corrupted just as the computer is indicating.
I don't know how important these files are to you but I'm afraid you might loose them because they are corrupt.
To fix this problem, you need to format the recorder and by so doing you will loose all your files but the recorder will be okay. You will have to put fresh files on the recorder.
Your computer may have been the one that corrupted the files on your recorder.
To format the recorder, while the recorder is connected to your computer, click start menu, go to computer. You will see a drive representing your recorder, right click on the drive, scroll to format and click it. This will format your drive and your recorder will be fixed.
Note, that you will loose all the files on your recorder in the process of formatting.
Good luck.
2helpful
Transfer digital recording to computer to make CD
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer. After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
1helpful
I am trying to transfer files from my Hotmail account to Olympus
If they are files that someone has emailed to you, they need to first be saved in your C drive somewhere and then you can import them to the DSS software to be able to play them. They cannot be imported directly as an email attachment.
26helpful
2answers
File transfer VN-480PC doesn't work on notebook (Vista)
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
2answers
I made a BIG mistake with a RP5120 RCA Digital Voice Recorder
If you remember what file name was given to that file, then use Windows Search option and locate that file any where in computer.
Please don't mention file extension, just put file name in search box.
Hope this trick will work.
2answers
Transferring files from folder to PC
you can copy the file you want (not move) and then erase it using the buttons on the device itself.
WS-110 will not turn on
My dear, what u did cause data damage and that's why it turns off the display. call the company and refresh or reload the software.....
that's it.....
have a nice time....
Files do not appear on PC
the computer not support the file format. use DSS player to convert the file format to wav and then to any other audio format. or use the SONY LAS VEGAS 7.0 OR 8.0 to convert it into required format.
best of luck.
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
