20 Most Recent RCA RP5022 Digital Voice Recorder Questions & Answers
  1. Turn on the player.
  2. Press Erase, Delete will flash on the display.
  3. Press and hold Record for three seconds. Format will flash on the display.
  4. Press and hold Erase. Wait will show on the display, formatting is in progress.
  5. After the formatting is complete, the remain time of the selected memory will show on the display.
This will format your voice recorder and delete everything on it.
RCA RP5022... | Answered on Oct 02, 2019
I'm pretty sure if you formatted it, it erased all of your recordings and you won't be able to get them back. That's for about anything you own and reformat it....digital camera sd card, hard drive on video camera...etc
RCA RP5022... | Answered on Feb 11, 2013
Press and hold MENU for three seconds.
RCA RP5022... | Answered on Jan 31, 2012
Press and hold [MENU] for three seconds.
You may view the manual here.
GET MANUAL AT WWW.RCA.COM ... UNDER AUDIO / VIDEO LINK.
RCA RP5022... | Answered on Feb 19, 2011
Sounds like you've lost the user manual...go to www.rca.com ...manuals and downloads are in the Audio/Video link.
RCA RP5022... | Answered on Feb 14, 2011
Iin this case, You can solve this problem by running "Error Checking" on your computer. You Go To: "My Computer" and find your RP5022 Drive Listed there. "Right Click" on it and Go To "Properties"...Once Open Click On "Tools" and Look for the Window that says "Error Checking". Click On "Check Now" when it Opens (Be Sure) to (Check the 2 Boxes) Listed. Let it run the Error Check...AND RESTART YOUR COMPUTER WHEN FINISHED.hope this helps.
RCA RP5022... | Answered on Jan 04, 2011
Hi
Please click on below link to view/downloadf the user manual for RCA RP5022
RCA RP5022B User manual
Hope this helps...
Daniel
RCA RP5022... | Answered on Oct 09, 2010
the files on your voice recorder is actually corrupted just as the computer is indicating.
I don't know how important these files are to you but I'm afraid you might loose them because they are corrupt.
To fix this problem, you need to format the recorder and by so doing you will loose all your files but the recorder will be okay. You will have to put fresh files on the recorder.
Your computer may have been the one that corrupted the files on your recorder.
To format the recorder, while the recorder is connected to your computer, click start menu, go to computer. You will see a drive representing your recorder, right click on the drive, scroll to format and click it. This will format your drive and your recorder will be fixed.
Note, that you will loose all the files on your recorder in the process of formatting.
Good luck.
RCA RP5022... | Answered on Sep 24, 2010
I turned my recorder on one day and only had 20 min of recording time and it was nothing on it took me awhile but i figured it out you have to put it on your pc and reformat it when i did that i got back my 26 hrs of recording time hope that helps
RCA RP5022... | Answered on Aug 02, 2010
DVD players normally don't have amps built into them. If you need to connect the DVD to amp (AV) then it will need to be connected either via an RF lead connected via RCA sockets marked RF OUT on the DVD player and one on the AV marked RF IN. If the AV has an optical in, then you can connect the DVD to that for better quality sound. You might also need to change the sound output settings on the DVD player to the correct one you are using.
Missing speaking sounds are the result of a lack of a centre channel speaker. If your AV doesn't have one. Then you will have to use the stereo only setting.
If the DVD player is only currently connected via the standard RCA left and right jacks, you will only get stereo sound.
RCA Audio... | Answered on Oct 12, 2019
If you're trying to put an equaliser in between a source and an preamp or integrated amp, the amp needs to have tape OUT or dubbing OUT connections. This will go to the eq's IN. Then eq OUTs should be connected to the tape or dubbing IN on the amp. When playing any source you set the amp's source selector to tape or dubbing IN and now what you are hearing is coming through the equaliser.
RCA Audio... | Answered on Oct 05, 2019
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_0.jpg For more details, check: How to Download Music from YouTube to iPod
RCA Audio... | Answered on Sep 19, 2019
This could be anything but I would guess you probably have a short in the system.If you could give me more information I may be able to help you better.
hardrocko
RCA Audio... | Answered on Sep 11, 2019
RCA RP5022 Digital Voice Recorder Logo
Popular Tags
20 questions posted
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
need manual rca rp5022b
  • Audio Players & Recorders
