20 Most Recent Olympus WS-100 Digital Voice Recorder Questions & Answers
if you were able to format the recorder thru the recorder.. it should be ready.. but if formatted through the computer, the files needed to operate the recorder are lost and you will need to send to repair to get the files put back on there
Olympus WS-100... | Answered on May 13, 2018
There is a way to format this device. If you press the menu/folder button a couple of times, you should see a blinking message that says "FORMAT" with a "no" centered above it. If you press the "forward" button, you will change the "no" to a "yes" and you'll have to "play" to change the option to "yes" which will reformat the unit.
Good luck!! This worked for me!
Olympus WS-100... | Answered on Sep 18, 2016
We had a similar problem (it wouldn't turn on), and it turned out that we hadn't taken off both layers of clear packaging from the batteries. It now works.
Olympus WS-100... | Answered on Aug 08, 2015
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Olympus WS-100... | Answered on Jul 14, 2015
hi, do you have the original instructions that came with the device.
Olympus WS-100... | Answered on May 30, 2015
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
Olympus WS-100... | Answered on May 26, 2015
Maybe you can rely on a Do It Yourself data recovery software to help if the storage device of your recorder is good. This recovery tool is able to recover audio, video and photo files. Good luck.
Olympus WS-100... | Answered on Apr 05, 2014
Olympus WS-100 Digital Voice Recorder Logo
149 questions posted
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
voice recorder turn
  • Audio Players & Recorders
