20 Most Recent
RCA RP5010 Digital Voice Recorder Questions & Answers
Can't record anything new
You can either use the "Digital Voice Manager" (loaded from the recorder when you first plugged it into a USB Port... OR, when you brought up the files in the recorder, clicked on the folder with setup). Or, if you just want to clean out everything from all four (A-B-C-D) folders, you can format the chip. Turn the recorder "on", press and hold "erase" until it flashes, press and hold "record" until it flashes "format", and press and hold "erase". "WAIT" will show on the screen until the chip is formatted, and you now have a clean chip - 128 meg or thereabouts.
Rca rp5120-a
The model which I have has a built-in file that downloads to your PC that installs a program for converting your .voc files into either WAV or EXE. The program can be copied and shared as there is no registration, however it would appear designed to work specifically with this particular device.
I have an RCA Rp5120-a digital voice recorder. I
first bring it in on a pc use the soft ware in the rca recorder then save as a wav because ti is voc file..so now it is a wav file you canplay a wav file if you can't.open it in quictime and save it in quicktime and every plays QT. thank you hope this works
How do I turn it on
There is two red lights, one means you are recording and the other is low batt. which one you are talking about?
If it is Low batt light,there is dirty or bad contacts at battery compartemt. clean it with alcohol and a piece of cotton.
The other light is you are recording.
also you are in VOX mode, disconect.
VOX means voice operated without hands.
