SOURCE: Sony Trinitron kv-32hs500
plug out the tv and let it stand for about 2hrs so that it can reset itself if that does not work take the set to a tech for repairs the problem is in the power supply and related circuits good luck.
SOURCE: sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I
have over 10 years experience in electronic tech
support.
I
know this isn't what you want to hear, but the problem you've
described can't be fixed with troubleshooting.
Your TV
will have to be repaired. There is a part that has developed a defect
and needs to be replaced. If you're still in warranty, the TV will be
repaired at no charge to you. The warranty would likely be at least
one year from the date of purchase from the manufacturer. If you
purchased an extended service
plan
they will repair the TV at no charge as well.
If the TV is no
longer in warranty, it will likely cost a minimum of $150 parts and
labor. This is assuming that you only need one circuit
board
or small part. If the problem is more than one of the circuit boards,
the price of repair could go much higher.
I hope I've provided
you useful assistance and that this information allows you to make an
informed decision as to how to proceed from here. Please be sure to
vote on my response. I hope I've earned a good rating from you
today.
Please let me know if I can be of further assistance.
SOURCE: Need a manual for a Sony Triniton KV-27542 TV
You can download your TVs manual here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV27S42&LOC=3
Testimonial: "Thank you for the speedy answer. Now after reading the manual, I should be able to operate the TV. I was unable to find this info on my own."
