I HAVE SONY TRINITRON MODEL
Hello
Your TVs horizontal sweep section does't works. it may be due to the fault of LOT [Line Output Transformer] or is related circuits. If you have some knoledge in electronics you can check these by yourself. I doesn't understand the problem correctly, because I don't know the language you expressed. Anyway I advice you these, and you just try to do it.
Open your TV, and locate its power regulator section. It can be located easly, as AC power diretly goes in to that section. There will be small transformer, and is called SMPS transformer, which gives voltage to the rest of the circuit You just measure its secondary side DC voltages. There must be a 130VDC point there. Check whether this voltage is present or not. You should have a multimter to measure this.
If this voltage is Ok, then go to the LOT side, that is the Line Output Transformer, that connected one of its wire directly to the picture tube, with a rubber ******. This is a stepup transformer, which works at 15626Hz oscillator drive frequency. The above said 130VDC will go diretly to it, after a resistor or so, and this 130VDC is only meant for working this transformer.
If it is not there, follow the printed track, and find where it breaks, and retify the problem. If it is there,a nd still your
tv has no picutre, it needs further checkups, and will have a perfect knowldege in electronics, and have ablility to follow the schematic diagram of the TV.
Anyway you just understand my language, and try to rectify your problem. If you want further assistance, please be free enough to do so, and get me through Fixya.
Please express your ideas and wants, in English language, even though there will be some mistakes on your expressions, I'll understand it and will give you replay. OK.
