20 Most Recent Sony FD Trinitron WEGA KV-34HS420 34" TV Questions & Answers
U have a thermal/intermittent issue. Given the age of the set and fact that other areas are now going, I think the cost effective way is to replace the set.
Sony FD... | Answered on May 02, 2017
check the power supply, its not giving out the required voltage output. if you cant repair a tv plse take it to a workshop, ask a technician to make sure that he checks the following components.
power diodes and transistor, fusable resistors around the power supply, and zener diodes.
he should make sure that an ht of 95-110 volts appears on the line transformer. later a transformer will produce various voltages to trigger other voltages to open up your tv. thanks
Sony FD... | Answered on Apr 07, 2017
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
Sony FD... | Answered on Jan 25, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sony FD... | Answered on Dec 30, 2014
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sony FD... | Answered on Sep 07, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sony FD... | Answered on Jul 29, 2014
You should download the repair manual to this set to know more about this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
SMPS [Power supply] circuit diagrams to many popular brand TVs are given. It cannot be attached here by this window.
Sony FD... | Answered on Jul 17, 2014
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Sony FD... | Answered on Jun 12, 2014
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Sony FD... | Answered on Mar 20, 2014
Download the repair manual to this set. It has all details. Repair manuals are in PDF, and cannot include here by this window. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Sony FD... | Answered on Jan 05, 2014
Refer TVs' user manual for details.
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
Popular Tags
345 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
got problem tv sony trinitron kv xg29m20
  • Televison & Video
