20 Most Recent Sony KV-27S66 27" TV Questions & Answers
2answers
How can i check IC601 (SRTF6626)? my tv doesnt
Try to check this link it has a schematic diagram of your IC.http://www.alldatasheet.com/datasheet-pdf/pdf/108380/ALLEGRO/STRF6626.html hope this may help you good day and best regards.
6/15/2012 1:55:07 PM • Sony KV-27S66... • Answered on Jun 15, 2012
Sony KV 27S66 - When
Hello
Blinking of standby light in Sony sets anre fault indications. There will be a specific number of blinks for each fault, from which we can understand the actual fault section inside your Tv. Count the number of blinks by Switch On and Switch Off by its front panel ON-Off switch for atleast 3 times, and confirm it. Just send me the exact number of blinks through Fixya. I'll assist you Ok.
8/17/2011 4:04:37 PM • Sony KV-27S66... • Answered on Aug 17, 2011
My standby/timer light is flashing
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
6/8/2011 3:39:48 AM • Sony KV-27S66... • Answered on Jun 08, 2011
Sony Kv27S66-I'm seeing horizontal lines
You must pull the main board out and re solder the vertical IC. This IC is mounted on a large heat sink. I remember that this vertical IC is of the TDA series. It would have seven pins. The pins will have to be re soldered, please do not use too much solder. You do not want to short the pins with excess solder. Next, you will need to check and replace the capacitors that are near and next to the vertical IC. We are talking about four capacitors, in this area. These caps, when weak, will create those horizontal lines you talk about. Second, the weak cap will cause the vertical IC to over heat and the pins will separate from their perspective grounds. Thanks for asking me, and show all hands of support!
5/6/2011 3:58:08 AM • Sony KV-27S66... • Answered on May 06, 2011
Hey! I'm trying to turn
Hey there,
Is it set to the correct input?
There should be a button on the set or on the remote called "input" or "source".
If you're trying to watch tv, make sure it's set to Cable, etc.
Hope this helps!
3/24/2011 8:34:14 PM • Sony KV-27S66... • Answered on Mar 24, 2011
My television has a blue
Hello
Your telivision may have its Chroma Ic faulty. Sony TVs uses their own coded numberd Ics, usually begin wi CX xxxxxx, or Philps TDA series Ics. These Ics contains so many sections integrated to one. That is Horixontal, Vertical, Synchronisation for both horizontal and vertical, video out drive section and its matrix, video If section, sound filtering section and so on which comes over 68 sections or so.If any of the among said section gets faulty, your tv will have some problems.
Here you can see a Blue screen. Therefore video out section of your TVs Ic is working well. The red flashing LED in the front of your tv indicates that there is some kind of short, not direct short, inside your TV.
You just do one thing. Open the back cover of your TV and find out the IC I have mentioned above. Switch on your tv, wait for 5 minutes or so, switch it off, unplug it from mains, and touch on the surface of the said Ic with your bare fingers and find whether it is overheats or not. Such types of Ics can be heated upto60 to 65 degree C. Not much more. If that Ic is faulty, it will heat up to a condition, which you can feel.
If there is no overheating is noted, there may be some low voltage missing. Sony TVs works on 112vDC main rail, 8VDC secondary rail, 5VDC for system control section, and 24VDC and 18VDC for vertical output and sound output sections.
Normally we noted is the missing of 8VDC rail. This 8VDC is derived from the secondory voltage of LOT, through a stepdown *V regulator Ic. If that Ics soldering point gets loose conatcted, of that Ic itsef is faulty, This kind of fault can occur.
If you are going to do it by yourself, keep the children away, and let an adult beside you as a precautionary measure. Never touch any part inside your tv while power supply is on. Take out power plug from the socket before touching any parts.
As yours' is a 27" TV, at about 25KVDC [25,0000VDC] points will be there inside. Keep Caution. Ok
10/20/2010 8:16:40 AM • Sony KV-27S66... • Answered on Oct 20, 2010
Tv cut off and the
Sounds as if your timer is stuck on. Do you have the original remote to this television.? If so, does it also have a dvd or vcr recording device built in? If it does you need to go to the menu, if you can bring the menu up at all, and find the timer settings, and try to get the timer off. If that doesn't work, try leaving the tv unplugged for a while. Hope this helps you.
8/7/2010 10:56:41 PM • Sony KV-27S66... • Answered on Aug 07, 2010
Lines on screen
try to reduce the screen adjustment of your tv.the adjustment is located at the crt socket board turn it counter clockwise....if it doesnt work check for open resistors on the G2 connection from the plyback it is a high voltage resistor replace it..
6/4/2010 2:35:27 PM • Sony KV-27S66... • Answered on Jun 04, 2010
No Picture
4 flashed on that model mean a vertical deflection trouble.
Look for solder on it. IC 541 TDA 8172.
4/23/2010 2:24:27 PM • Sony KV-27S66... • Answered on Apr 23, 2010
Picture turns on and off and the color is a
yes. you are not getting green. sony has a circuit that if the picture is not perfect, it will shut off. two solutions....one, take off back and with the tv on, tap pretty hard but not hard enough to break it, on the neck of the picture tube with the plastic end of a phillips screwdriver. this will shake the old sediments in the crt. the tv will probably shut off if you do it right. tap harder and harder many times. fixed. two, rejuvinate the picture tube. fixed. easy
11/13/2009 2:49:53 PM • Sony KV-27S66... • Answered on Nov 13, 2009
TV will not stay on
Fault are on the high voltage section, mostly the transistor
9/5/2009 9:43:47 AM • Sony KV-27S66... • Answered on Sep 05, 2009
My sony kv27s66 turn on than off after one sec
the tv got problems on the power suply thats why going on to protection mode
8/25/2008 5:24:45 PM • Sony KV-27S66... • Answered on Aug 25, 2008
Tv blinks twice
ak-blinking needs caps and resistors changed check Q601,Q602,T603
1/18/2008 10:12:55 PM • Sony KV-27S66... • Answered on Jan 18, 2008
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 2 days ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered on Apr 21, 2024
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
Sony KV-27S66 27" TV Logo
19 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv27s66 39 m seeing horizontal
  • Televison & Video
