Bring up the photo on the camera.
Press up or down until you get the histogram (yellow graph). When you
get this, press up once, and look at the bottom of the screen.
Once the date has been stamped on the pics, they're their just like anything else in the pics. You can use a photo editing program to try to remove them, but it's the same process as trying to remove an unwanted object from any other part of the picture.
After downloading the photos to your computer then click on Date created at the top of the your picture folder. The photos will the sort by the date the photos were taken starting from the earliest date. If you click on Date created again it will sort by the latest date the photos were taken.
Once that is on the pic the only way to get that off would be to crop the picture or else when you print the picture make sure that your DPOF is shut off. Then the date shouldn't print on there.
go to function and change pic size to wide or it shows a w -then you will see in main menu highlight of time and date stamp-canon can only do date and/or time in a certain size pic-rember it's a lower quality resolution than normal-change pic size first at bottom of function menu then go to main menu
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Curiously, the first pictures I took with camera had the date stamp on the pics so somehow the date did appear but probably disappeared when the batteries were changed.
