20 Most Recent
Sony Cyber-shot DSC-S750 Digital Camera Questions & Answers
I have lines across all of my pictures all of a
I an ensure you that is not a setting! That is the CCD sensor and i would be checking that into a camera shop if i where you to see if the camera can be fixed or not. I could not tell you over the web as I have not looked at the photos for the output but it seems pretty bad if your seeing lines on every photo or let alone any photos. Best advice do not shoot the messenger here take it ot a camera dealer/shop havei t looked at.
thanks ofru sing fixya.com please do leave you positive ratings and feedback. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
How to reset
Try resetting the camera by removing the battery for 15 mins. Then install the fully charged battery in the camera and go to the menu and set the Date and Time.
I lost my Cd bought with Camera
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Flash is not working
how repaire blitz camera samsung s750, becouse i'm counfiusing..helft me me please.
How to clear memory card
Clear the memory card by formatting it. Press the MENU button, press cursor-right, select the toolbox icon, press cursor-right, select the memory stick icon, press the button at the center of the cursor pad, then select "Format".
Where do you plug in the charger
One end of the cord goes into a wall outlet, the other end connects to the battery charger, not the camera. Take the battery out of the camera, put it into the charger, and plug in the charger. See the illustration on page 10 of
the manual.
I want to download driver for Sony cybershot DSC -S750
Picasa.
Owner's manual for sony cybershop camera
You may download a copy of the manual
here.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
here.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
I cannot get my computer to recognize the downloaded CD for the Sony Cyber-shot DSC-S750
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or
Picasa.
Photos are striped and the screen display is also buggy
With the photo's being striped it leads me to believe there could be a crack or even just dirt on the lens. Might be the same thing with the display. Have you dropped it or taken it to the beach or anything where moisture could have gotten into it?
Our camera seems to be okay but when i'm
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, try taking a picture with the screen black. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so,
please see this link for further info and a simple fix that may help.
How do i get date
According to the user manual, your DSC-H55 doesn't have this function.
Pls i need the software
You can download Sony software from
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCS750
My Sony Cyber Shot has
I'd suggest talking to where ever you get them printed as it's likely a setting on their computer doing that.
