20 Most Recent
Nikon COOLPIX L810 Questions & Answers
Lens will not retract Monitor bland.. error message turn camera off remove lens
Hi.
I experienced the lens error message after taken the camera to the beach. Sure enough, there was sand all over the lens mechanism. First, I cleaned the area by blowing air to remove all sand particles (this took me almost a day). In my case, I did not have to remove the lens from the body of the camera. Once clean from dirt, sand or any other foreign object replace the batteries.
Camera wont snap picture
As long as the orange light is on, the camera is not ready to make a picture. The focus area, should become green, to tell you the camera is in focus. Then you can press the shutter release button complete. Check the settings of the camera, and put it in automatic. When you put it in one of the manual modes pipe P M S or A, the camera will not take a picture when there is not enough lift or something else you did not take in account.
If the camera keeps this way, unless you switched to auto, it could be there is something going on. but let me know it auto des not work.
Won't turn on
Always be sure the battery is charged and suited for your camera.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Lens stays out
Lens chamber might be damaged, Consider replacement of lens gears/assembly.
Camera is not recognized by pc
any card over 4gb will not be read by older computers. If you don't have a newer computer the SD card reader, avliable at walmrt under $10.00 will work.
Nikon Coolpix L 810
It would help to know if the lens extends when you turn on the camera. Assuming it does and that you have made a setting error rather than a functional issue; reset your menu settings. If you do not have a copy of the L810 instruction manual, you can download it for free at
http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L810RM_CH(11)03.pdf. Go to page 65 and follow the reset instructions. If you still have the problem, contact Nikon Service at 1-800-645-6687 between 9AM and 8PM EST, Monday through Friday for a repair estimate and instructions.
