my dvd's are now playing in b&w - when I installed the dvd player last fall to my magnavox hdtv in was in color, but now only plays in b&wmy dvd's are now playing in b&w - when I installed the dvd player last fall to my magnavox hdtv in was in color, but now only plays in b&w
You can't post conmments that contain an email address.
It sounds like you have a standard problem. Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video? Check to see what is required and set the DVD player accordingly. Hope that helps.
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
please reset the factory seetings in uer dvd player, throgh menu button on uer remote. Firstly open uer tray and after take rhe menu and select factory reset, and reset it,
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Here's what's going on with that unit. The DVP3340 records on the vcr side only, not the dvd side. To record on the VCR side, you would have to plug a red, white, and yellow plug from the red, white, and yellow OUT of your cable box to the red, white, and yellow VCR IN of the Philips. The manual, as far as I can see, only shows hookups for playback, not for recording. Good luck!
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
