20 Most Recent Philips Magnavox DVD Player MWD200F Questions & Answers
2answers
I have a dvd player
This DVD player only supports DVD and Audio CD format. There is no Divx decoder so your avi. files wont play on this player.It does not even support MP3 music files.
5/7/2020 8:47:00 AM • Philips Magnavox... • Answered on May 07, 2020
3answers
Magnavox mwb multiregion hack
icon_minipost.gifRegion code posted by paulstoner75, January 25 2008:
This player is manufactured by the Funai Corporation for Magnavox. This is a very basic DVD player, and despite it's many features, it is not bad for a $31.99 player from Wal-Mart, however...
After speaking with the Funai Corporation Support Line, they have no problem giving out region hack codes for other models they make such as Symphonic, Emerson, as long as the user understands if you make a mistake and something happens, not their fault, etc..
For this basic player - No codes exist.
2/13/2013 9:10:59 PM • Philips Magnavox... • Answered on Feb 13, 2013
It won't play my dvd-r's
It never will. You can try to copy the DVD to a +R instead.
6/25/2012 1:08:50 AM • Philips Magnavox... • Answered on Jun 25, 2012
4answers
I need the code Magnavox MWD200F DVD Player.
The code for MAGNAVOX MWD200F is 447 (247 partially works). It had been tested in two Philips universal remote controls (CL015 and CL035A).
Greetings
CRENDON
1/26/2012 10:57:44 AM • Philips Magnavox... • Answered on Jan 26, 2012
How can my dish network remote controle my tv and
You will do best trying what is called a Power Scan this will allow you to scan for all possible codes and try out functions as you go!
1.) Press and hold the clear VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network
Customer Service
6/11/2011 2:50:44 AM • Philips Magnavox... • Answered on Jun 11, 2011
Is there a drawer release
Sorry - The unit has no such "emergency eject" function/release.
Regards, Mikeywaf
3/3/2011 4:52:13 AM • Philips Magnavox... • Answered on Mar 03, 2011
It won't play anything. It
have you tried a DVD/CD player cleaner on it? if it does nothing you may have to manualy take the DVD player apart and clean the laser head
you have to take some Q tips and gently very gently rub the little head on the unit then you should be good to go if not then the head is shot and the dvd player needs to be replaced
1/2/2011 2:52:08 AM • Philips Magnavox... • Answered on Jan 02, 2011
The volume is messed up. I can turn my TV up all
You will probably need instruments (voltmeter, oscilloscope) to track down this problem.
At first I was going to suggest there is a fault in the audio buffer amplifier, but the only way that would be the case is if it is the bias circuitry inside a chip shared by both the left and right sound signals, or a power supply problem. The other possibility is the voltage reference for the Digital-to-Analog Converter (DAC).
How it works: the DAC gets the digital audio information from the DVD data processor. It generates an output voltage that is a fraction of the voltage reference value. For example, suppose the voltage reference is 2.5 Volts, and the audio data for the right channel is a 1 followed by fifteen 0's (half of full scale, which is sixteen 1's). The audio DAC should produce 1.25 Volts on the right channel. The audio DAC is almost certainly a dual channel device, and uses one voltage reference for both. If the voltage reference is putting out a very low voltage because it is bad or overloaded by another part, you would get the symptom you are having.
What to look for: identify the audio buffer amplifier IC (trace the circuit back from the sound output jacks). While a DVD is playing, use an oscilloscope to compare the input waveform with the output. You will probably have to search for and download the datasheet for the amplifier IC so you can see where the left and right input waveforms go in. If they are the same amplitude, or the output is larger than the input, the amplifier is probably OK. If not, check the voltages on the other pins on the chip to make sure they are correct. In particular, look at the voltage on the pin labeled "Vcc" or "Vdd" on the datasheet. It should be the same as one of the voltages printed by the connectors coming from the power supply board (give or take several tenths of a volt). If it isn't you'll need to check the power supply voltage with an oscilloscope to see if you have a bad capacitor. It is common for the first capacitor in a power supply filter to fail while the second one is good. This can produce a low voltage output that may still look like a clean straight line on the scope. However, for an audio amplifier, the result would be a low-amplitude, distorted sound.
If all is well with the audio amp, you will have to find the audio DAC chip. Start by downloading its datasheet and identifying the voltage reference input. Measure the voltage there. If the DAC has an internal voltage reference, look for a pin that provides this voltage externally.
Cautions: the laser in the DVD player can cause permanent eye damage if it is accidentally viewed directly. If the player mechanism does not have a cover built into it, put a sheet of opaque material (e. g., cardboard) over the DVD drive while you work on it. Keep your fingers away from the power supply, especially the high voltage section where the power cord comes in (often outlined on the power circuit board with white or black dashed lines, bridged only by transformers and several small parts). Get an anti-static wristband, put it on and connect the lead to the metal case of the DVD player. This is so any static electricity you build up in your clothing won't destroy parts in the DVD player. The transistors inside the integrated circuits, especially the data processor and DAC, are very delicate, and can be ruined by a discharge too small for a human to feel as a shock.
This is probably a "hobbyist" repair job. It's my understanding that this model is worth under $35, and most professional technicians want a minimum of $50 just to look at it. If you get lucky, you may find another unit of the same model that is no longer reading discs (try your local electronics recycler). You can swap the mechanism or main board with that unit to get one working (observe anti-static precautions with both parts - the laser circuit is also vulnerable to electrostatic discharge).
12/6/2010 7:16:18 PM • Philips Magnavox... • Answered on Dec 06, 2010
I cannot get the tray to go in! Its stuck somehow
The spindle must be completely down first and then the tray will be inserted. That is the standard mechanical sequence.
8/3/2010 12:31:58 PM • Philips Magnavox... • Answered on Aug 03, 2010
Philips Magnavox DVD Player MWD200F Logo
63 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
dish network remote controle tv
  • Televison & Video
