20 Most Recent
Philips Magnavox Learning Universal Remote Questions & Answers
Code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
Samsung bn59-00516A is stuck on cable
It sounds like you have a problem with your 'main board'. It's board where all the outside connections come in or as we used to call it the 'tuner board'
Gillight
Samsung remote BN59-00516A is stuck on cable button
Try spraying tuner cleaner down beside the button. Be sure you get a good turner cleaner like Chemtronics. If that doesn't work you will have to disassemble the remote and check the membrane under the buttons. If the button is used a lot it may be torn or wore out.
Gillight
Living Solutions Remote - Manual
press and hold Tv VCR or DVD wait until the red light turns on then press power. Now press channel up or down until the the device turns on if you press it again while the device is on you'll have to do it again. After that hit OK then test it by pressing the volume button
I have Magnavox television model number TP2770
There may be a way to get to the audio and video without a remote by first pressing the menu button on the front of the set (if there is one), but the easiest fix is to invest in a good universal remote which will allow you to open the full TV menu. From the start up menu the remote will, after matching the code, allow you to go deeper into the start up menu to the audio/video menu and on to the "regular TV mode".
