20 Most Recent Philips Magnavox DVD/VCR Dual Player Questions & Answers
Hi.
I'm sorry, but according to zenith xbv323 VCR/DVD combo user's manual page 24 you can ONLY copy DVD to VCR and not the other way
Philips Magnavox... | Answered on Jun 28, 2019
Either your lens of the dvd player is dirty or the dvd's you put in have no data on them
Philips Magnavox... | Answered on Jun 04, 2019
Most branded DVD's have a country code programmed in it.
There is no code to reset it.
It is better you buy a local chines make kinda dvd palyer. It will play all and comes cheap.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Philips Magnavox... | Answered on May 22, 2019
Ok well I have a brand new disc from the store with Percy Jackson movie on it and it will not play. The disc plays in other players in the house and other discs play in the player just not this one.
Philips Magnavox... | Answered on Aug 24, 2018
If this is the only VCR you have which is displaying this tape problem, and the tapes are new, it sounds to me like the entry guide (also known as a base incline unit) might need to be either re-aligned or replaced (this is located on the left-hand side of the head drum) it could also be the back-tension band which may have come loose or broken - if it's broken, this should also be replaced. Back-tension is also on the left side of the video deck. Check the tape guide tracks (both left and right) for any foreign objects such as fragments of plastic, and perhaps consider replacing the pinch roller and cleaning the entire tape path before using anymore new tapes in it. Clean the heads as well to complete the job.
I have found in the past with videos like these, that the top of the tape playback picture begins to 'tear' and noise is audible in the Hi-Fi track. The entry guide has always been the culprit, adjustment has not always been a viable option. If you do replace this part, you may need to align it to the VCR mechanism for optimum SP/LP performance. There are a few simple cheap ways to do this; the easiest is to record a tape in SP and LP in a GOOD machine (which has no problems) then play that tape in this one - to check alignment. try adjusting the guide carefully with a precision/jeweller's screwdriver first before ordering any replacement parts. Because this guide is threaded, you should carefully turn it anti-clockwise with minimal pressure - this backs off the over-track or tearing at the top.
Good news, if as you say the DVD part is fine, no problems, and the machine powers up, etc., just the tape issue with VCR, this should be a simple fix if you know how it is put together. You shouldn't need service manuals for this, and you save a fortune in workshop labour charges!
I hope this suggestion helps a tad. If you're careful, you won't have any further problems with it. And the left guide is easier to replace than the right.
Philips Magnavox... | Answered on Jul 28, 2016
PAL /SECAM European system switched for america its ntsc Maybe there is dvd firmware-release update usefull neccesary its not free of land region code.
Philips Magnavox... | Answered on May 08, 2016
Philips Magnavox DVD/VCR Dual Player Logo
869 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
disc error playback feature may not
  • Televison & Video
