20 Most Recent Philips Magnavox 50ML8105D 50" HDTV DLP TV Questions & Answers
Hello
Just surf through this website and try to get your Philips TVs manual. If you fail to download it from there, send ma a mail, or send your email ID to me by Fixya. i've the manual you need, and will send it to you by return mail. OK.
deltamanual.com/.../philips-magnavox-50ml8105d-50-in-hdtv-dlp-tv-dlp- magnavox-manual-tv.html
Philips Magnavox... | Answered on Apr 08, 2019
Please try a new main board first.
Philips Magnavox... | Answered on Nov 01, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Philips Magnavox... | Answered on Jun 04, 2017
The Magnavox tb110mw9 has NO controls on the box. without the remote you cannot operate the box.
If anyone knows of a universal remote or similar remote (philco) will operate the box please post.
Philips Magnavox... | Answered on Aug 17, 2016
Debris that collected inside the TV had magnetic properties and when you blow the dust around some tend to collect on the inside of the screen. Do not touch that screen with your hands, or try to wash it. The inside has a special coating to enhance the projection image. Once damaged, it needs to be REPLACED. Try a NEW clean Swiffer and lightly brush away dust particles. Do not use chemicals or dusting sprays.
Philips Magnavox... | Answered on Mar 18, 2015
It is likely a bad fan that gets quiter as it warms up from use. There are two fans on that TV - one under the bulb housing and one at the left vent hole. They are special fans with three leads - +, - and an RPM indicator (yellow lead typically).
Philips Magnavox... | Answered on Mar 12, 2015
This problem is typically caused by one or both of the cooling fans in the set going bad. The fans are located under the bulb housing and on the side of the set at the left vent hole. You can check the status of the fans by using your remote to access the TV's set up menu as follows:
Select "source" on the remote
hit the "up" arrow twice
hit the "down" arrow twice
hit the left arrow
hit the right arrow
hit the left arrow
hit the right arrow
At the setup menu select the item that says something like "thermal status" or "thermal properties" and look at the speed of the two fans. Properly working fans will have a speed of 1500 RPM or more - they should be close to 2000 RPM. If the fan speeds are less than 1500 RPM this will cause and overheating problem and they should be replaced.
Smart is a word often used to suggest a device does more than other devices. It does not imply it can go on the net by just pressing any button. You first have to setup everything, as the manual will explain. Don't trow away the manual and ask someone else you don't know, to write the pages you need to setup anything.
Philips Magnavox... | Answered on Jan 13, 2015
This simply sounds like a "remote address" problem, in other words--the remote is not assigned to the set. If this is for a DVD or VCR, you might have to assign that function before they work--by pressing the "dvd" or "vcr" button before they work.
Philips Magnavox... | Answered on Oct 03, 2014
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
598 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
turn magnavox tb110mw9 analog
  • Televison & Video
