20 Most Recent Philips Magnavox MWD7006 DVD Player Questions & Answers
Have you gone on the menu settings in your U-verse cable box. Under the menu settings in the the cable box go left all the way over to options. Under options there is a remote control set up. There they will give you some sets of codes to try for your product.
Philips Magnavox... | Answered on Jun 06, 2014
Hi Chuck, I copied this from the MWD7006 manual - I hope it helps.
If your TV is compatible with 525p (480p) progressive scanning and you want to enjoy that high quality picture, you must use Component Video cable connection and progressive scanning mode.
To set the mode, set "PROGRESSIVE" to "ON" in SETUP menu, so that the "P-SCAN" indicator on the front panel lights up.
When "PROGRESSIVE" is "ON", video signals from the unit's VIDEO OUT and S-VIDEO OUT jacks will be distorted or not be output at all.
If your TV is not compatible with progressive scanning, use this unit in interlace mode and set "PROGRESSIVE" to "OFF" either in SETUP menu, or by pressing and holding [PLAY B] on the front of the unit for more than 5 seconds, so that the "P-SCAN" indicator on the front panel lights off.
Download Magnavox MWD7006 Owner Manual
Philips Magnavox... | Answered on Feb 01, 2014
4 digit code is 0458
Philips Magnavox... | Answered on May 03, 2013
one of these philips/magnavox codes should work press dvd and ok buttons then release - the top row of buttons will blink twice - then enter 4 digit code - after which the dvd button will blink twice - then try power - if fails - try next code.
2002, 2018, 2032, 2033, 2045, 2051, 2089, 2091, 2109, 2169, 2208, 2209, 2222, 2237, 2241, 2243, 2259, 2260, 2264, 2270, 2282, 2285, 2293, 2302, 2304
Philips Magnavox... | Answered on Sep 16, 2012
Download the user manual to your set from net. Click here to download it. It will ahve all details.
Philips Magnavox... | Answered on May 23, 2012
Setting your DVD player to be region free is a daunting task.
The easier way to go about this is to download ANYDVD, http://www.slysoft.com/en/anydvd.html
Rip the DVD to your computer and Re-burn with the correct region code.
Philips Magnavox... | Answered on May 09, 2011
Change the format of your movie to an AVI. or MPEG before burning it onto your DVD.
Philips Magnavox... | Answered on Mar 05, 2011
Hi designer it has to with the power voltage. And it select because not ALLmovie are to be played in the DvD. Work on the power pack that sustain it.
Philips Magnavox... | Answered on Jan 21, 2011
are you putting disc in right way up?
Philips Magnavox... | Answered on Oct 29, 2010
Philips Magnavox MWD7006 DVD Player Logo
57 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
get higher 480p resolution playback
  • Televison & Video
