Dishes on top rack are dirty and bottom rack are clean. not overloading washed nothing still the same problem...
After washing, glasses on top rack are dirtier than when I put them in! Bottom rack is getting clean, top rack is not. Nothing seems to be wrong with the dishwasher. It is a 2-1/2 -year old Frigidaire. Am using Lemi-Shine and Cascade Complete. Water is hot enough, nothing is clogged. Any suggestions? Thanks.
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
My dishwasher is not cleaning the dishes on the top rack, we did everything suggested above. Arm under top rack is not moving, soap dispenser opens, water not hot. Nothing is clogged we cleaned everything! Please help us solve this problem! Thanks!!!!
