20 Most Recent Kenmore 15529 Built-in Dishwasher Questions & Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Kenmore 15529... | Answered on Aug 05, 2011
This is most likely either due to a clog in the drain line or the seal around the sump being at fault. It depends where your unit is leaking from. If you remove the bottom kick plate from the unit you should be able to see where the water is leaking from if it is in the middle of the unit most likely you would have to replace the sump and sump gasket if it is off to the side of the sump then it might be the drain pump being clogged or blocked with something that is makeing it leak. If you have any further questions message me back and Thanks again for using Fixya
Rick
Kenmore 15529... | Answered on Jun 11, 2011
Do you hear a 'click' when it is supposed to start filling the machine--if not, then the water inlet solenoid has likely failed. Make sure the water is turned on under the sink and there are no kinks in the supply hose. Hope this helps!
Kenmore 15529... | Answered on Sep 22, 2010
Either the lock is faulty or the program is midway .
You will need to inspect the lock mechanism, use a good degreasing spray if the lock is struck. If not the lock reset from end of cycle is not reset.
Must check this out.
Kenmore 15529... | Answered on Sep 17, 2010
You must take the door apart to lube / repair the linkage
Kenmore 15529... | Answered on Jun 11, 2010
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Kenmore 15529... | Answered on May 15, 2010
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Kenmore 15529... | Answered on Aug 24, 2009
look inside the tank for a float or probes.clean them real good and see if this helps.
Kenmore 15529... | Answered on Apr 24, 2009
Do not know about a recal. But you can buy the racks at your local Sears service senter or on line at www.Sears.com
Kenmore 15529... | Answered on Dec 17, 2008
I found a plastic cone shapped part in the bottom and can not figure out where it goes. thanks
Kenmore 15529... | Answered on Jun 29, 2008
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Kenmore 15529... | Answered on Apr 12, 2008
Kenmore 15529 Built-in Dishwasher Logo
Popular Tags
27 questions posted
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
kenmore dishwasher model
  • Dishwashers
