Using a test light, the wire shows to be "hot". however, when I connect to the fixture, nothing happens. When I place the test light on the place where the wires connect it will not work, but if I d
HI Jack,
Can you give more details? Is this a house circuit that you are working on, or some vehicle?
In either case, look thoroughly through the ground side, or common side.
With 120 volts, it is possible to have voltage present, sensed with a voltage "sniffer" (needs no direct contact, works by induction) and no go of what you are powering.. My guess is this is not the type of circuit you are working on.
With 12 volts, it is possible to have power, and read with a test light type of tester or VOM. Again, look at the ground side.
SO, another possibility is that you have a "cold" circuit. This type of failure is because of poor, damaged or corroded connections somewhere in the circuit. With this type of failure, you often can get a valid voltage reading, but the circuit fails when actual load is applied.
To find this type of failure (IN 12 VOLT systems), hook up the thingy that you are trying to power, set VOM to enough range, and check along each leg: Positive and Negative. Point to point. one end goes to Positive battery, for example, then you probe just after each POSITIVE connection, along the circuit. What you are looking for is a voltage. for example: a poor connection would have zero volts read on one side of the connection, but 2 volts just after the connection.
So, the quick way is positive battery terminal, to your device, then negative terminal to the negative on your device. One will give large reading. Investigate that 1/2 of the circuit, and you will find you issue.
Hope this helps, if not, get back to me.
Doc
