Water valve solenoid that supplies water to dispenser may be bad, or water filter needs replacing
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
SOURCE: The water dispenser stopped dispensing.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the water line in the door is frozen , GE has a dispensor heater which comes with instructions to install . Pt # WR49X10173 .
SOURCE: ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
I just used the hair dryer and it worked the water is flowing again out of the dispenser
this is not what I am asking, when the ice says to add water to ice maker instead of going in ice maker it comes out the door
Water dispenser works but warm water. no ice made
The water dispenser works but not water to ice maker. Where can I start to figure out the problem?
Water dispenser makes loud nose and very little water
Noise when dispensing water and low water flow
The water dispenser is dispensing water but the ice maker is not making ice
No dispension of water or ice
No water or ice from dispenser
I cannot get water, ice nothing in the dispenser will work. Totally shut down
Both are not receiving water
ice maker not making ice
water ice dispenser
but will make ice
Ice machine makes ice and the water dispenser will dispense water. Ice will not dispense through the door.
ice maker not getting water
